Old 10-23-2011, 08:43 PM   #16
J-milz's Avatar
Trader Rating: 38 (100%+)
Thanks for all the help.....Again the reason I initially asked the question was to help me decide to either use my Novak 17.5 motor that I ran from Short course which seemed "slow" when compared to other 17.5 trucks with the same gearing.
I was planning on running that same motor in a blinky touring class at a local carpet track and was unsure of the proper way to go. Also if it was possible to economically change just the stator for $35, or spend the $85. However when I ran at that track today, I received alot of good tips from the racers at the track, and I just decided to go with a new motor.
Thanks for the positive input.
💫XRAY addict💫 sponsored by the secret stash.....tee-hee-hee.
J-milz is offline   Reply With Quote
Old 10-26-2011, 08:52 AM   #17
WC
WC's Avatar
Trader Rating: 28 (100%+)
motors taken from an SCT usually feel soft & need work
by the time you rebuild with new bearings (frontbell) & new rotor... yeah
sometimes better to buy another motor so you have a spare
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 03-08-2013, 08:27 AM   #18
performula's Avatar
Old thread I know, but I have a question.
If I have a 17.5T Thunder Power Z3R and want to convert it to 13.5T Z3R, all I would need is the stator correct? Or would I need the end cap and rotor as well?
This isn't for racing FYI just street runs
performula is offline   Reply With Quote
Old 03-08-2013, 08:32 AM   #19
MikeXray's Avatar
Trader Rating: 73 (100%+)
Correct, with TP you can swap the spec stators, only the MOD stuff is different. (I forget which one is a longer stator).
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-08-2013, 09:06 AM   #20
oeoeo327's Avatar
Trader Rating: 74 (100%+)
I'm pretty sure that 7.5T and higher-turn stators fit in the "stock/spec" can - any stator with fewer turns requires the mod can. Turning a TP 17.5 into a TP 13.5 requires nothing more than a stator swap.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 03-08-2013, 09:09 AM   #21
performula's Avatar
Thanks guys!
Old 03-08-2013, 12:32 PM   #22
J-millz, next time I'm at a track with you ill let you try my TP and Novak and they're both pretty much brand new.. Novak used once at horsham and TP used once at horsham and once at critters, to tell you the truth when I used th Novak at horsham my lap times were better than with the TP on the same layout and felt more consistent but the TP was a lot faster on the straight.. I am still pretty new to TC and was having a hard the day I used the TP but they're both good if you ask me
JOE SI is offline   Reply With Quote
Old 03-08-2013, 12:38 PM   #23
At critters last Sunday might have been my worst day so far, but my car with the TP was fast and could've made it faster for sure, I didn't even change the gearing and it didn't get passed 110 degrees the whole day
Manhattan Kansas area Racers and Bashers! buttere Kansas/Missouri Racing 6672 11-26-2017 09:00 AM
Novak Ballistic goes Spec kn7671 Electric On-Road 379 10-26-2016 09:20 AM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
