Old 11-28-2004, 11:45 AM   #1
AJ Racing's Avatar
Send a message via ICQ to AJ Racing Send a message via MSN to AJ Racing Send a message via Yahoo to AJ Racing
Cool I need Help about orion V2 motor !!!!
Hi i am jean and i race in malta in the modified class i am encountering problems with this motor all other competitors using this motor are menaging to get about 15runs out of a scimm i cant get more than 3 runs first of all i am running a V2 motor with an 8 single corally armicure on a Yokomo cgm running on 9.29 final drive any suggestions about motor maintinance ect ect
regards
AJ Racing is offline   Reply With Quote
Old 11-28-2004, 12:08 PM   #2
EddieO's Avatar
R/C Tech Charter Subscriber
Which springs are you using?
What is your timing set at?
What brushes are you using? How are you breaking them in....
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 11-28-2004, 08:09 PM   #3
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
If u cant get more then 3 runs, pls explain why.
You are not giving enough information for us to evaluate whats happening to your motor.
AdR|aN is offline   Reply With Quote
Old 11-29-2004, 01:50 AM   #4
Pro4's Avatar
Default Re: I need Help about orion V2 motor !!!!
regards
If you are running sprint brushes then you will get only a few runs with max. performance.
If the other guys are using enduro brushes then this explains why they are getting 15 or so runs
Pro4 is offline   Reply With Quote
Old 11-29-2004, 02:02 AM   #5
defMondo's Avatar
I usually get 8 to 10 runs in practice out of a set of sprint brushes sometimes more depends on how lazy I am, performance doesn't drop that much, when it does you know about it though.
I'm not sure what difference the corally armature would make but I have heard that low turn corally motors do not like a lot of timing, you should be running 10 degrees or less (just less then the second mark on the V2 can I think).
Tony
defMondo is offline   Reply With Quote
Old 11-29-2004, 08:48 AM   #6
AJ Racing's Avatar
hi juys thanks for replying about the timing its set at 4deg 2noches the springs are medume, the brash are sprint
eddieo what you mean
regards
Old 11-29-2004, 10:49 AM   #7
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
I believe EddieO is asking what compound of brushes Sprints or Enduros and how are you breaking them in - whats the timing at on your motor? How many amps? How long? Comm Drops or no Comm Drops?
dgullickson is offline   Reply With Quote
Old 11-29-2004, 11:20 AM   #8
EddieO's Avatar
Sprint brushes (without serrations, older versions had them) should be broken in at ZERO degrees timing at 2.5 volts for 5-6 minutes or until they are seated. A softer spring sometimes takes longer.
Later EddieO
www.teambrood.com
Old 11-29-2004, 11:41 AM   #9
AJ Racing's Avatar
the brushes i am using have no serrations they always give the better performance on second run
Old 11-29-2004, 02:06 PM   #10
Eirik's Avatar
regards
AJ Racing,
With a 8t motor you will need to run harder springs, go to the Hard Springs Part# 41393 this will make a huge difference!
Also 2 noches is like 12deg, try a timing around 6-8deg.
The Enduro brushes will also give you more runs betwen rebuilds, so I suggest you try those as well.
Cheers,
Eirik is offline   Reply With Quote
Old 11-30-2004, 01:02 AM   #11
AJ Racing's Avatar
thanks i will deffinitly go to johnbull today and get this model of springs will try them and let you know what results i get
regards
Old 11-30-2004, 01:33 AM   #12
johnbull's Avatar
Aw Jean.
As a starting point. 1 notch = 4mm = 12 degrees.
Use that as your basis for calculations on most motors.
I'll be in after 3pm today. Call and I can explain further.
I am getting better results with V2 ended motors all the time - and plenty of runs too. Might even use them on Sunday !
Bring your transmitter with you too.
johnbull is offline   Reply With Quote
Old 11-30-2004, 01:39 AM   #13
So each "notch" on the can (white or red line) is 12 degrees?
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 11-30-2004, 03:32 AM   #14
defMondo's Avatar
On Orion Revolutions white/red lines are 2mm or 6degrees, on other motors the notches on the actual endbell are 4mm or 12 degrees.
Tony
Old 11-30-2004, 09:31 AM   #15
AJ Racing's Avatar
thanks joe i will pop by tomorow after noon if tis ok for you
regards
MuchMore Motor Cooler + Orion Motor Performance Monitor mugengreg Australia For Sale/Trade 11 01-05-2008 09:56 PM
Which Peak/Orion driver with a motor named after them won their title w/Orion or Peak Bobby J Electric On-Road 24 03-05-2006 04:37 AM
Team Orion Motor Checker/Motor Run In Unit Jammin J R/C Items: For Sale/Trade 7 01-20-2005 05:38 PM
Indi motor dyno vs. Orion Motor Perf monitor j240z Electric On-Road 5 08-07-2004 03:58 PM
Kyosho 1/8 Suzuki Motorcycle With Team Orion Coreless Motor And Team Orion Flash Esc hpidriver R/C Items: For Sale/Trade 3 07-04-2003 07:56 PM
