Old 10-20-2011, 08:31 PM   #1
Default Loctite Free Screws and Bolts
I'm thinking of marketing screws, nuts and bolts for R/C Cars, Planes, and Boats that do not require the application of loctite but retains the torque capability of loctite without the mess. Therefore, the loctite type application will be applied through a manufacturing process for the most common sized screws and bolts used in R/C. In addition, the bolts and screws can be removed and reinserted over 100 times without losing its torque capability.
Let me your thought on this and if you would be instested. I am looking for people to test the screws in their cars and planes. If you are interested, let me know what size you need and I will send you some for testing.
Thanks,
Tim
Tim35 is offline   Reply With Quote
Old 10-22-2011, 06:45 PM   #2
WC
WC's Avatar
Trader Rating: 28 (100%+)
isn't that what Traxxas already does?
spares coming from TRX that includes machinetread screws
usually have 'dry' treadlock already applied...
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 10-24-2011, 06:39 PM   #3
I haven't seen these screws with the drylock already applied. Do you have a link to them? They must not be widely known yet.
Old 10-24-2011, 07:53 PM   #4
stiltskin's Avatar
Trader Rating: 102 (100%+)
Sounds like a good idea. If the parts are good, I don't think you'd have any issues selling them.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 10-24-2011, 11:36 PM   #5
I got some with threadlock on in AE kits a few years back (to hold steering blocks) this is a good idea, but the biggest problem is the quality of metal used in screws, many heads go bad if too soft or using poor quality tools.
If you have some to try, I'll be happy to do the "guinea pig" for you, my kits are TC6, so M3 size for all.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 10-25-2011, 06:32 AM   #6
WC
WC's Avatar
ppl just take it for granted
these are the 2 bits i've seen it on meself
Boca?
www.PandaGFX.com
www.MelbRC.org
Old 10-25-2011, 06:45 PM   #7
The hardware quality issue has been the major issue trying to obtain the hardware I need to test but I have found some 12.9 grade hardware to test the application today. I'l post the sizes I order tonight.
Old 10-25-2011, 06:53 PM   #8
avs
avs's Avatar
the kyosho evolva clutch has a red colored treatment on the flywheel nut. these threads hold the clutch preload setting.
i haven't seen a blue treatment, but 'vibra-tite' is a red material that is reusable.
Tony Shimko
avs is offline   Reply With Quote
Old 10-25-2011, 07:26 PM   #9
Hey Guys,
I have ordered the following sizes below for testing. Let me know if you are interested in testing any of these sizes.
M3x6mm Flat Hd. (countersink) Skt.
M3x6mm Metric Button Socket Screw
M4x12mm Metric Button Socket Screw
8-32x3/8" Flat Hd. (countersink) Skt. Screw
8-32x1/2" Flat Hd. (countersink) Skt. Screw
M3x10mm Flat Hd. (countersink) Skt. Screw
M2x4mm Socket Head Cap Screw
4-40x1/4" Socket Head Cap Screw
Old 10-25-2011, 08:39 PM   #10
Red, blue or yellow doesn't matter. The application can still be the same in any color.
Old 10-26-2011, 01:03 AM   #11
Hi Tim
If you want to send me a couple of the M3 to test, I'll put them where it might be the riskiest to get unscrewed, but I reiterate the fact that if the screw quality is poor, and the threadlock is "too strong" you will have problems with damaged heads.
pm me if you want.
Old 10-26-2011, 08:47 AM   #12
WC
WC's Avatar
12.9 sounds like he's gone hi tensile
dunno about your side of the globe but even the cheapest black steel screws
from china etc are still pretty decent quality, none so bad they're useless
much more common for RC'ers to have hopeless wornout tips on their drivers
www.PandaGFX.com
www.MelbRC.org
Old 10-26-2011, 03:07 PM   #13
That is the truth with any type of screw and driver combination!! You have to have qualitity on both ends or else it doesn't work. Maybe the screws will do the trick as I'm curious about the screws, the patch locking and how well they will work in the field overall.
Old 11-09-2011, 05:48 PM   #14
Default Good News!! The Screws are ready!!
Hey Guys,
I should receive the screws tomorrow and I will be sending them out to all of you who requested them on Friday. I look forward to you test results in the near future and maybe these screws will solve some of your current issues with Loctite.
Thanks,
Tim
Old 11-09-2011, 06:22 PM   #15
The Losi XX had dried Loctite pre-applied to the front axle scews back around '93-94.
Serzoni is offline   Reply With Quote
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11736 11-28-2017 09:10 AM
Malaysia Monster Truck thread.... faz1122 Malaysian R/C Racers 396 06-21-2014 01:42 AM
Loctite Free R/C Screws and Nuts Tim35 Nitro Off-Road 44 03-03-2012 09:33 PM
Remove Thread Lock mcsully Electric Off-Road 17 08-16-2009 08:59 AM
