Old 11-09-2011, 06:31 PM   #16
vabroom's Avatar
And those Losi screws had a lot of Loctite on them and you had to really kong them to get them out.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 11-09-2011, 06:35 PM   #17
WC
WC's Avatar
Trader Rating: 28 (100%+)
just curious what sort of issues ppl are having with Loctite?
if it ain't locking as it should... have they RTFM??
Threads should be degreased & loctite takes 4-6hrs to anarobic cure,
wipe threads with motorspray & i'll leave it unstresed for 24hrs if i can.
when at track... i don't bother with loctite for instant grab,
i use shoegoo (especially hot areas) or CA during pit repairs.
Loctite releases with heat, so even the red stuff is weak for engine screws.
Use a solvent type of loctite (gooey Tamiya Threadlock) or shoegoo.
Spillage? you can buy Loctite(tm) in a gluestick style
More often than not... its RC builders who have overtorqued your tiny screws
to beyond the metal's stretch point; when the shank is no longer elastic
the screw will never hold tight again & forever keeps backing out.
And take a tip from 1:1 cars... if there's screws that must never come out,
have a second mechanical way of locking them. Serrated or castlelated nuts;
for flat chassis bottom could be as simple as a strip of gaffertape or
scratchprotect film - stops all those flatheads moving until you want them to.
(when we build to 'enduro' spec, where its gotta last 3/4/5hrs not 6mins)
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 11-09-2011, 06:53 PM   #18
My screws have a 0 min cure time and when they are inserted they can be removed and screwed back in over a 100 times. Militray/Aerospace tested and approved. The stuff on these screws is way better than loctite. The proof will be in the testing! I'm sure they will live up too and way beyond the current solutions on the market today. Also, it won't eat the plastic like loctite or make it brittle.
Tim35 is offline   Reply With Quote
Old 11-09-2011, 07:03 PM   #19
WC
WC's Avatar
sweet - u can use the treated screws into plastic also?
www.PandaGFX.com
www.MelbRC.org
Old 11-09-2011, 07:08 PM   #20
yes, the same chemical adhesive is used on all laptops, iphones, blackberry's etc..It has been proven on those devices already in plastic with no problems.
Old 11-09-2011, 07:13 PM   #21
If the tests go well..I'll be adding screws which will be able to handle the heat issues without losing the ability to hold like the motor screws. The technology has been around for several years in use by the military, automotive, aerospace, NASA, and other areas but it has never been introduced to the R/C market until now. The closest it has come was the use on the drones or UAV's but not commercially in R/C.
Old 11-09-2011, 07:19 PM   #22
WC
WC's Avatar
ain't that much plastic screw wells left in Apple products,
especially unibody MB/MBA & iPhone4
even when they have screw holes in plastic case, they'll put a brass insert
(Its the pentalobe screwheads that annoy non-Genius tinkerers...)
www.PandaGFX.com
www.MelbRC.org
Old 11-09-2011, 07:33 PM   #23
I haven't had to disassemble my iphone yet! But I hear what you are saying about the plastic screw wells.
Old 11-10-2011, 06:32 PM   #24
Default The Screws are Ready for Shipment
To all:
If you are interested in trying any of the sizes below please send me your address if you haven't already. I'm sending out the screws tomorrow to those I have their address already.
M3x6mm Flat Hd. (countersink) Skt.
M3x6mm Metric Button Socket Screw
M4x12mm Metric Button Socket Screw
8-32x3/8" Flat Hd. (countersink) Skt. Screw
8-32x1/2" Flat Hd. (countersink) Skt. Screw
M3x10mm Flat Hd. (countersink) Skt. Screw
M2x4mm Socket Head Cap Screw
4-40x1/4" Socket Head Cap Screw
Old 11-10-2011, 07:04 PM   #25
Suspended
I hope your not using that same stuff that was causing all the Apple workers in China to get really sick and never be able to work again?
RogerDaShrubber is offline   Reply With Quote
Old 11-11-2011, 09:49 AM   #26
lol..no this stuff is non-toxic..In China, it was porbably some lead based component.
Old 11-14-2011, 09:43 AM   #27
WC
WC's Avatar
i hear its a solvent used to clean the glass surfaces before bonding together
www.PandaGFX.com
www.MelbRC.org
Old 11-28-2011, 09:53 AM   #28
Default Screw Tests
To all:
Hopefully everyone who requested the screws for testing has received them by now. Also, I was wondering if anyone has any test results from the screws and locking ability of the compound.
Thanks,
Tim
Old 02-04-2012, 10:25 PM   #29
Default The Stay Tight Site is Up
www.staytightrc.com
Old 02-25-2012, 09:58 PM   #30
Default Screw Kits are now on the site
The screw kits are posted on my website for a few of the TRAXXAS electric trucks and the SC10. I'll be adding more trucks and cars as well as titanium screws in both metric and standard sizes. Currently, there will be about a 1-2 week lead time on the kits. If you have a kit not listed on the site, shoot me an e-mail at [email protected] and I will add it for you and send you the pricing. The prices are a little higher than I wanted to list them at but keep in mind you won't be replacing screws for a very long time with these kits. In fact, they will probably last the entire life of the vehicle.
Thanks,
Tim
www.staytightrc.com
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11736 11-28-2017 09:10 AM
Malaysia Monster Truck thread.... faz1122 Malaysian R/C Racers 396 06-21-2014 01:42 AM
Loctite Free R/C Screws and Nuts Tim35 Nitro Off-Road 44 03-03-2012 09:33 PM
Remove Thread Lock mcsully Electric Off-Road 17 08-16-2009 08:59 AM
