Old 11-28-2004, 10:25 AM   #1
Shotcke diode needed?
I'm trying to clean up the wiring on my 1/12 scale car. Is a shotcke diode needed on a 27 turn stock motor when little or no braking is used?????
rollover is offline   Reply With Quote
Old 11-28-2004, 10:26 AM   #2
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
no, unless you are using a Hara Twister or KO speed control.
tc3stocker is offline   Reply With Quote
Old 11-28-2004, 01:49 PM   #3
I'd use one any way, on every speedo just in case. It's not going to harm it if you do put one on
Chazz
Chazz is offline   Reply With Quote
Old 11-28-2004, 07:21 PM   #4
one for and one against........any others?????
Old 11-28-2004, 07:25 PM   #5
stumper1's Avatar
R/C Tech Charter Subscriber
What kind of speedo?
stumper1 is offline   Reply With Quote
Old 11-28-2004, 07:34 PM   #6
LRP IPC Sport Digital and quantum sport. There is no braking involved on the local track.........unless you are headed straight towards a wall!
Old 11-28-2004, 07:45 PM   #7
picco007's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
edit
EA Motorsports
picco007 is offline   Reply With Quote
Old 11-28-2004, 07:47 PM   #8
picco007's Avatar
I'd put one on just to be on the safe side. If your in a crash or you hit the wall it may help the life of your speedo, there probably is some arcing when that happens so it's probably safer.
EA Motorsports
Old 11-28-2004, 07:48 PM   #9
The quantum sport was just sent in for repairs after a crash! Both have had diodes installed. I am wondering if they are needed or not.
Old 11-28-2004, 07:49 PM   #10
stumper1's Avatar
I agree - as long as you DO NOT HAVE REVERSE I would use one.
I mounted a Novak diode directly to my Quantum. Takes up very little room and I don't have to solder/de-solder them on the motor all the time.
Old 11-28-2004, 08:00 PM   #11
koabich's Avatar
Send a message via Yahoo to koabich
Correct me if I am worng, but you are not supposed to use schotty diodes with any ESC that has reverse!
koabich is offline   Reply With Quote
Old 11-28-2004, 08:04 PM   #12
stumper1's Avatar
You are correct. That is exactly why I said........
Old 11-28-2004, 08:06 PM   #13
These are both forward/brake only speedos.
Old 11-29-2004, 04:56 AM   #14
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
What exactly do these diodes do?
Team Duratrax is offline   Reply With Quote
Old 11-29-2004, 05:08 AM   #15
asw7576's Avatar
to filter motor spikes between 1% to 99% throttle range.
to absorb excess current while coasting and braking. In short it makes your ESC runs cooler.
What does a schottky diode do? MK_Arbiter Electric On-Road 36 04-11-2007 07:07 AM
diode harddrive Electric On-Road 10 02-27-2006 10:40 PM
Schottky Diode Info Needed!!! 2BAD4ALL Electric On-Road 1 12-09-2004 07:53 PM
Cyclone Profile Help Needed - ?? about Diode & Capacitor rctoyguy Electric On-Road 6 07-12-2004 03:11 PM
schottky diode ????? drx Rookie Zone 2 04-29-2004 04:17 PM
