Old 11-28-2004, 07:53 AM   #1
lastplace's Avatar
Send a message via Yahoo to lastplace
Default GFX mod question
I've seen several post where the power cables on a GFX are rerouted out the back of the unit. In one case banana plugs where added to the back. I have already reroute the charger cables out of the front panel and like it much better.
My question is; when drilling through the heat sink do you remove it from the unit? If you do remove it, is it only the 4 or 5 screws that come off the circuit board
lastplace is offline   Reply With Quote
Old 11-28-2004, 08:28 AM   #2
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
I routed my power cabels through the back of the gfx. I cut the alligator clips off it. You do need to take the heatsink off and drill the whole larger to fit both the fan wires and now the power wires through the whole. I removed the screws for the fets that mount to the heatsink and that's all you need, the heatsink pulls right out. You don't need to remove the screws that attach the board to the case.
Good luck, the gfx is much better with them coming out the rear not the side.
John
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 11-28-2004, 08:43 AM   #3
lastplace's Avatar
Thanks John,
It will be "upgraded" by tonight.
Might just add a colored fan while I'm in there.
Old 11-28-2004, 05:38 PM   #4
lastplace's Avatar
Mod done! Took less than a hour, added a color fan just for the hell of it.
Old 11-28-2004, 07:39 PM   #5
Look good buddy
John
engine question and radio question alucard13 Nitro On-Road 12 09-12-2008 09:21 AM
Bolink TF drag car question and BL question parnelli97 Electric On-Road 2 08-20-2007 06:32 AM
This is gonna sound stupid question but I have a battery Question. Smoke21 Electric On-Road 7 04-25-2004 09:10 PM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 12:46 PM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 10:33 AM
