Old 11-27-2004, 08:20 PM   #1
drx
drx's Avatar
Send a message via AIM to drx
GMVIS Commander HELP
I need some help setting up a GMVIS Commander (2000?).
Anyone?
Email, PM, or online?
</drx>
drx is offline   Reply With Quote
Old 11-28-2004, 08:03 AM   #2
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
whats the question..........
I have one and use it continually
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 11-28-2004, 08:13 AM   #3
drx
drx's Avatar
Great!
Actually I have questions on a couple topics with the Commander, but lets start with peak charging.
How is your box configured for this - specifically The bottom row (amps, mah, volts) and why. Also how do you set dpeak and why?
That'll do for a start.
TIA
X-man
Old 11-28-2004, 08:26 AM   #4
I always set my amp rate of charge @6.0amps for six cell packs and 4.5 for 4 cell packs. The delta peak I keep at 5mvp (I think thats the letters but you get the point I think) 5 is safe for your cells. I always set the mah at to what ever the pack is rated at.
Have never had a problem using this set up.
Hope this helps.
Next Question.
Stephen <><
Old 11-28-2004, 09:12 AM   #5
drx
drx's Avatar
This is great.
But what of the mah and volts?
I have mine set to 3300 as that's what the cells are.
The volts setting, though, is a bit confusing.
If I set it to 7.2v the system won't charge. Iy just goes to the "READY" state. If I set the volts to something like 9.0 volts it charges. I also find it interesting that while charging he volts vary and hang around 8.5 volts +/-. What's up with this?
I also have some ?s about the dPeak, but lets ddress this first, okay?
</x>
Hope this helps.
Next Question.
Stephen <><
Old 11-28-2004, 09:26 AM   #6
Michal101's Avatar
Originally posted by drx
This is great.
</x>
drx,
First, I would read the manual and see what the engineers suggest as far as setting up your commander.
Next, I would set the mah rating at 1.2 times the rating of the battereies...ie the 3300 should have a mah setting of 3960.
Also, the reaon why your commander is saying "ready" when set at 7.2 volts is because your 6 cell battery pack sitting dorment is probably around 7.2 volts. Depending on your battery packs (matched or unmatched, new or old) the peak voltage can reach over 10v when charged so start with this number and see how the pcaks perform.
Remember that these setting are mainly for safty cutoffs to ensure that your batteries do not get over charged and ruined.
I hope this helps, Mike
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Michal101 is offline   Reply With Quote
Old 11-28-2004, 09:38 AM   #7
drx
drx's Avatar
Mike,
That's a help to be sure.
I HAVE read the manual. It's not much help. Have you ever seen the manual for this thing? Not that good.
Why set the mah to 3300 x 1.2? I'm not doubting you - not at all. Just curious to know why is all.
Volts - did you mean set to 10v?
thanx a million
</x>
Old 11-28-2004, 10:24 AM   #8
Michal101's Avatar
Mike,
thanx a million
</x>
drx,
Actually, I used to have 3 of these great chargers. The reasons that the capacity of your batteries could be higher than the 3300 rating and the setting of 3960 allows you to fully charge your batteries with a safety precaution of not over charging.
Yes, set it to 10V to have the charger stop charging if the voltage of the charging battery pack reaches 10v, but please remember to test the battery pack to see if it is fully charged.
You can charge them via temp mode if you have the optional temp probe for the commander. This is probably the best method. The temp should be around 115 to 120 degrees when fully peaked.
Mike
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Old 11-28-2004, 11:22 AM   #9
drx
drx's Avatar
Thanx Mike,
That explains a lot.
Speaking of the temp probe, where can you get one in the US? Having a tough time finding one for sale (retail).
</x>
Originally posted by Michal101
drx,
Mike
Old 11-28-2004, 11:29 AM   #10
Michal101's Avatar
Thanx Mike,
</x>
I would try Horizon hobbies since they import GM Racing products.
Mike
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Old 11-28-2004, 11:39 AM   #11
drx
drx's Avatar
Mike
Tried that.
Didn't appear to be in their online catalog.
I suppose they could special order one.
I found a hong kong shop that carries it, but would prefer to keep my business closer to home. Besides, the shipping from HK doubles the price.
Old 11-28-2004, 07:07 PM   #12
There is a place in Austrillia and shipping isn't as bad.
http://www.greatmodeldeals.com/suppo...ht_catalog.htm
You have to email them with the part numbers you are looking for. If you scrool down you will find the GM94400.1 for $29.71 I believe shipping was like $7.00
HTH (Hope this helps)
Stephen <><
Old 11-29-2004, 09:50 AM   #13
post above or below depending on settings has been edited for more info.
Thanks,
Stephen <><
GMVIS Commander FS / FT The Wease R/C Items: For Sale/Trade 18 08-18-2005 09:49 PM
Gmvis Commander jc510 R/C Items: For Sale/Trade 19 07-08-2004 03:28 PM
GMVIS Commander robk R/C Items: For Sale/Trade 5 09-24-2003 10:12 PM
GMVIS commander dimples Electric On-Road 1 02-09-2002 03:20 PM
GMVIS Commander RBLove R/C Items: For Sale/Trade 2 11-24-2001 11:31 PM
