Old 10-27-2011, 06:31 PM   #31
Infinite 12th's Avatar
Originally Posted by Big Midget View Post
sorry but what do you mean buy ''if the tires are loaded''?
He means if weight transfer is to fast/abrupt towards the limit of grip then less traction is obtained
Maybe think of it as full tire patch consistency...lol
Hence the middle of the tire gets more time to be placed on the road surface vs. from side of tire to side of tire
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 10-27-2011, 07:22 PM   #32
Suspended
Totally true about weight transfer ! I limit my weight transfer time by using heavier oil (60wt to 80wt) instead of relying on finger control only ....
bertrandsv87 is offline   Reply With Quote
Old 10-28-2011, 04:23 AM   #33
Thumbs up
Been aggressive does that mean breaking hard ? here's a video of some of the top players i saw recently , i think been gentle on the breaks makes you smoother ...
http://v.youku.com/v_show/id_XMzE1MzA5NDQ0.html
vm2 ,tm e4,mi 4,cup racer,yokomo d1,TCX,PHI RDX,MI4CX,TC6,china made pro-d.
ps.just came back to this hobby this year after22 years .
oldnoob is offline   Reply With Quote
Old 10-28-2011, 07:57 AM   #34
Big Midget's Avatar
Trader Rating: 100 (100%+)
I run 40wt and 35wt....
So will a heavier shock oil smooth out weight transfer?
UltralineHobbies.com
Ultraline Raceway Topeka Ks
Dee & Mee Hobbies RickyRacer Lidz,Absolute Tattoo,Fuzzy Dice Decals
Big Midget is offline   Reply With Quote
Old 10-28-2011, 08:09 AM   #35
I run 35wt and 40wt....
The spring and oil work as a team so depending on your spring rate you should adjust your oil
But I think the topic is more about keeping the car as flat as possible leaning forward/backward and side to side and if more damp in relation to your spring does that then you are correct hence smoother is again faster because the grip limit is not approached to suddenly
lol
Old 10-28-2011, 10:10 AM   #36
hana166's Avatar
Yes it does, but if too heavy the car will not transfer quickly enough, and slide. You're always searching for the correct amount of reaction, experimenting with oils is one of many factors which all interact with each other..one of the reasons this hobby is so interesting
For example I use 350 sometimes 450CST, and use front anti dive to reduce the weight transfer, so I can get the faster reaction of the thinner oil for quick direction change, whilst still keeping the car stable on entry and exit
hana166 is offline   Reply With Quote
Old 10-28-2011, 10:54 AM   #37
Johnny Wishbone's Avatar
Lots of people don't like this but another adjustment to change weight transfer is Anti-dive, don't be afraid to try it. It will stiffen the front "feel" or dive of the car, almost like splitting a spring and oil selection. I find it slightly stiffens the front feel and also settles the back of the car down. Give it a try, it could surprise you.
***Sorry didn't see above post, but same info.
Gary Lanzer
Old 10-28-2011, 01:19 PM   #38
Suspended
Good Johnny, I also have anti dive dialed in, but with the lowest possible roll center... It really works wonders.....
Old 10-28-2011, 04:38 PM   #39
Big Midget's Avatar
Thanks for the info guys. I only get to race once a month during the winter but we get 2 hrs of practice time before the races start. I'll try some things out.
Thanks again.
Old 07-07-2015, 05:46 AM   #40
JamesHealey's Avatar
I know this is an old thread but a fascinating subject all the same.
I think what people mean by "smooth" is how you don't ask too much of the car during weight transfer situations by abrupt inputs, this will just unsettle the car and cause it to be unpredictable.
You tend to see really aggressive drivers who hack at the wheel, like quite a safe setup, one where the rear end stays put and they really need to throw the car at the corner to get it to turn in some times even braking whilst turning to upset the car a little, this works with certain people and it's just one driving style, they tend to be able to get on the power then really early and aggressively because the back end is safe.
Smoother drivers tend to like a car that has a lot more mechanical grip on the front axle, they're generally smoother with the steering input and smoother with the throttle on the way out, this gives maximum mid corner speed.
Both styles are fast which ever works for you works for you, but there's no harm in trying to be smoother.
I tend to start turning for the corner way earlier than needed and really slowly feed the steering wheel on to see how much grip the front axle is giving me then feed in until the car has touched the apex, at this point start ramping up the power really fast, smoothly but fast whilst unwinding the steering, if the car steps out you've lost time, as Jackie Stewart said don't get on the gas until you're sure you won't have to back off.
I'm not the fastest driver but I think the philosophy is correct.
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
