Old 03-11-2005, 02:53 PM   #271
Send a message via AIM to Rudedog55
Default catch up
you had better hurry up dom were almost on page 10
Rudedog55 is offline   Reply With Quote
Old 03-11-2005, 03:00 PM   #272
litespeed-dom's Avatar
No doubt!
Also, I saw that your batts are in the middle position? That would have something to do with as well.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 03-11-2005, 03:02 PM   #273
Default batts
brians original set up was batts forward, so i moved them back and it helped a little, should i go all the way back??
Old 03-11-2005, 03:46 PM   #274
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Default TQ vs Paragon
Yea, what Dom is saying: the amount of grip that Paragon produces in the rug is vastly different then what TQ does to the rug. Take a car that uses a fraction of traction on a front tire on a Paragon track and bring it to a TQ track... same car needed a lot more sauce on the front to make it steer. I know that this is probably not new news to anyone, but it's something to be vary aware of. The big thing is to get the balance right away for 8 minutes and then tweak from there. I know that I could not use side springs on a Paragon track, where it was manditory in Salem (TQ).
Rudedog- there is always something that I remember. Look tire split. Bigger split = more stable, smaller split = more aggressive.
Brian
Slapmaster6000 is offline   Reply With Quote
Old 03-12-2005, 12:57 AM   #275
RedRocketRacing's Avatar
Slapmaster-
Rumor has it you liked all the color my car had. I think it adds character. Talk to you later.
"Red Rocket"
BTW You want to start distributung those T-Bars for me?
How about the Spur Gear?
RedRocketRacing is offline   Reply With Quote
Old 03-12-2005, 10:57 PM   #276
Default The 1 minute twitch
Brian,
Remember the 1 minute twitch that you experience at RC Plus? Or was it 30 secs twitch? And then the car pushes in the last minute? Apparently it is something that not only the spanker is experiencing, looks like the faster CRC are doing the same thing. Car is just evil to drive in the first minute, then it pushes in the last minute. Your theory on too much traction compound at the beginning and not enough mechanical grip at the end is definitely spot on. However, I really don't know how to cure the problem. Here is my setup.
BTW, TQ, track record and win again today. I'm on a roll! Or I'm having some real good luck lately.
pink/dbl pink...small tires, 1.78 rear
.020 fr springs
middle roll center
even caster shims
.075 t-bar, 2 screws on bar
green spring, 30wt oil
Losi hydra fluid (regular) on tubes
2 .020 side springs in each tube, .020 preloads
batts back
3.25 ride height all around
just a touch little over 1/2 TQ sauce on front, full rear
Wes surprisingly ran .018 front springs in the main and he finally got the handling back on his T-Force.
My cornering speed is real good, gives me a lot of confidence while I'm on the track. My back end is just planted, it's not going anywhere, but the first minute twitch and last minute fade is really something else. I want to say that I'm already used to driving with the twitch and fade, but I'm sure there is a better setup for an entire 8 mins. After talking to couple of guys (Ellis included), I'm beginning to think it just might be the characteristics of the track??? I really don't want to think that way, but I'm starting to question....
Your thoughts?
Dom
Old 03-13-2005, 12:56 AM   #277
Hi gang,
Great 1/12th thread ya got going here. Keep it up, it great to hear the healthy 1/12th chat.
Hey Brian, I just couldn't let this one go...
When you say purple stuff in the side tubes, do you have the old Hyp tubes or the newer CRC copies of Hyp tubes?
CRC was the first to bring aluminum tubes to the mass market in 1997. I designed the current aluminum tube, with it's taper and bleed hole after being dis-satisfied with the plastic Bolink tube. We have made subtle changes to the tube to improve it over the years. It appears that the Hyp tube is a pure copy of our tube, shortened a bit. CEFX has copied the tube as well. Seeing how we have never seen Hyp tube, I can tell you we certainly didn't copy it.
Sorry to jump in... that copied thing just kinda hit a sore spot.
Frank
Team CRC is offline   Reply With Quote
Old 03-13-2005, 05:29 AM   #278
Default 1 minute twitch
dom you are right on th money, that is the exact problem i have, i have made some changes last night to see if it will help, i'm off to hobbychamber, we should have a good turnout today, 1 week before nats.
Mr.Calandra didn't get a chance to say hello at the jan jam, i'm in pit 49 come say hello next week!!
later
rudy
Old 03-13-2005, 10:13 AM   #279
Default Flatery
Hey Frank- you know what they say, that copying is the sincerest form of flatery.... it just doesn't line the wallet very well. When you have something good, people will notice. I am aware that a few are after my diff trust kits. I feel that it is just too good of an idea to go unnoticed. What do you think of yours at this point?
Dom/Rudedog- think of the twitch in this way. If you put too much traction on the front end, it will be twitchy to drive; right? If you don't have enough mechanical front grip in the car, it will push. Now that you get both of these conditions in 8 minutes should tell you that the car is out of balance and that you are making it do some things that it doesn't want to do. So the answer should be to use less front traction and to put more mechanical grip into the car. I was able to get the car farely consistant at Salem start to finish, so I know that you can do it too.
Dom- you might go to 22/20 on the side springs, chrome or blue on the center spring, might add that 3rd spacer, 1/4" of front traction, 3/4 & 1 on the camber and toe out to suit the track needs.
What you are doing here, is making more off power steering, freeing up the rear end just a little and using less chemical traction to achieve a better balance then before. Give it a try.
Nice job, keep gettin' 'er done!
Old 03-13-2005, 10:19 AM   #280
Default Re: Flatery
That's my thought on the spring and spacer too. I'll try the 22/20 springs.
As much as we both love driving gas cars outdoor, I wish I have a few more club races left, seems like I'm just starting to comes to term with the car and making progress.
Brian, I also emailed you earlier about something else.
Dom
Old 03-13-2005, 12:16 PM   #281
Send a message via AIM to jumbo360
Sounds like you've been having a great week Dom keep it up.
Justin
jumbo360 is offline   Reply With Quote
Old 03-14-2005, 10:31 AM   #282
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
Dom, all
I have experienced the twitch thing with all of my 12th cars. I find if I can really wipe down my front tires well before the race the twitchy is reduce greatly. Just giving them a quick wipe with a towel doesn't work that well, I spend nearl 2 full minutes on the front tires alone. I also fond that cleaning my tires with motor spray helps to keep the grip for longer in the race.
Chris.
crimson eagle is offline   Reply With Quote
Old 03-14-2005, 01:01 PM   #283
Yea I heard motor spray works but I heard from a friend that some people use lighter fluid on there foams to take out the compound so it would work as if it were brand new, never tried it though.
Old 03-14-2005, 01:17 PM   #284
Default LIGHTER FLUID
i used the lighter fluid trick this weekend, went to a lighter damper tube fluid, and the twitch went away!!! now if i could just find a cure for backmarkers!!!! my white rag is now black from all of the residue off the tires. also cured the heavy pivot i was experiencing.
Old 03-14-2005, 01:22 PM   #285
The Fog's Avatar
Dom and the twitches. I know the feeling oh so well at Salem. My best efforts on that track come with a great deal of cleaning the fronts with motor cleaner, then laying on a good dose of TQ for 25% of the inside edge. A previous note made mention of this. After much battle with my bloody Bloody Knife, I cracked my 50 lap thresh hold by two laps and missed a 53 by 0.23 or summut. This took a gold spring and 80 wt on the Silver shock. The back end was brill like this. The main revalation was with the tyre washing and the increased consistancy, came the fact that 10 degree blocks threw on too much caster gain in all corners. Uncle Chad suggested a couple of degs extra toe out ta boot and that was a plesant suprise. Felt like turn in was mitigated for the first half, but then weight transfered and camber gained and whoops, there we go twitching again.
Super cleaning the tyres though, is my way out of this pit. Can't wait to see Dom burning his tyres !!
Mostly, I have to work on my own body twitches more than anything else.
Jacko
The Fog is offline   Reply With Quote
Slapmaster MS 2.3 1/12th scale harjo R/C Items: For Sale/Trade 4 01-09-2008 03:24 PM
12th scale MS2.3 Slapmaster fjm9898 R/C Items: For Sale/Trade 4 07-29-2007 10:59 AM
Slapmaster MS2.3 12th scale fjm9898 R/C Items: For Sale/Trade 17 06-30-2007 06:06 PM
SLAPMASTER MS2.2 1/12th scale nhra6849 R/C Items: For Sale/Trade 16 12-26-2006 12:55 PM
Slapmaster MS2.3 12th scale stumper1 R/C Items: For Sale/Trade 11 09-03-2006 02:28 PM
