Old 01-29-2005, 01:35 AM   #151
revzalot's Avatar
Originally posted by fast-ho-cars
depends on the track quality you race on:
the Majority at our Hobby town track run either a gurney off the body or a wing mounted off the rear pod. (old school) we had problems running any mod motor due to traction problems at the rear so we went to stock but still had inconsistent handing at the rear. tried adding a gurney flap (like the 12th body that Protoform has on the Speed-12) at the rear of the body. the handling improved a little but not much. so me an another old school 12th racer decided to put wings on the rear pods like we did back in the 80's thru early 90's. first some other drivers scoffed at it. now 4 of us are running them. with 3 others looking or waiting for the shop to get some more wing mounts in. we do modify the body by cutting away some of the kickup on the rear of our bodies when we add a pod mounted wing
prior to that, I was racing 12th mod on carpet with the latest bodies and had no problems. no extra d-force required. however when our shop pulled the carpet and put in a dirt oval. because i don't run offroad or dirt oval, i was forced to run at our local Hobbytown on asphalt track/outdoors. the asphalt is blown off but not prepped (sugar water, thinned out VHT, sugared soda water) like asphalt tracks i ran on years ago. they also run offroad races on the same day and dust travels.
at ROAR races this add ons are not legal, however would't be needed because 99.9% of the time the track will be properly prepped with no offroad races 15ft from the asphalt track
Interesting. Do you have pix of the old school wings and modified bodies?
www.revzalotmotorsports.com
revzalot is offline   Reply With Quote
Old 01-29-2005, 10:29 AM   #152
fast-ho-cars's Avatar
sorry no pic capability
use wing mounts like those sold by racewaymfg.com. take a 3/4" bolt cut off the head (clean up the threads) screw it into a wing mount and crew that into the right rear hole on your top pod plate. i then drilled a hole on this plate about a 1/2" to the left top pod plate screw and mounted the other wing mount with a screw from underneath. bent a piece of piano wire like this:
sideview
_____________________
top view
_________________________
[_________________________
i use AE nylon wing mount buttons for the wing $1.50 and for a wing i use a offroad wing that will fit between the shark fins on my Speed 8. i trim the wing so it has about 1" on flat area and 1/2' kickup only.
put two 3/4" holes in the top of your body were the wing mounts/wire will come thru to allow free movement.
i run a Speed 8 with the curved up area cut away. you can have too much downforce even on a dusty track causing the car to twitch in turns
move the wing back on the wire for more downforce and forward for less.
hope this helps
fast-ho-cars is offline   Reply With Quote
Old 01-29-2005, 11:35 AM   #153
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
Hi Dom,
yes I have seen those, but I have only seen them in white, I really want to ues black, and also the dubro quality isn't great, the one's I am using are very good quality. I personally like using the standard size, they are a way better fit and they do not pop off as easily. I also use titanium ball studs so wieght is not a big factor. Last time I wieghed my car it was 806gms with big wheels, it's only getting lighter.
Chris.
crimson eagle is offline   Reply With Quote
Old 01-29-2005, 12:00 PM   #154
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
Default Re: Possible t-shirt design!
Originally posted by Slapmaster6000
A racing buddy of mine, is a graphic arts designer. He has some pretty snappy computers to play with and has some pretty creative skills to operate them with. He also shares the same sence of humor to go along with Slapmaster Tools and the MS2.2 line. Not that I don't take this seriously, but we do race these cars for fun... and I hope to remind us of that! Bill, also is going to put the website together, but we gotta have shirts first!
Brian; [email protected]
i think i need on of those shirts, as well.... those ROCK!
nothing like showing a monkey's ass at the track!!!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 02-02-2005, 01:03 PM   #155
revzalot's Avatar
sideview
top view
hope this helps
Thanks for the how to but I'm having a hard time visualizing on construction. I'll try to google around to see a picture of it.
Old 02-03-2005, 12:42 AM   #156
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Default Tire update
Hey MS Fans,
Andrew Cartwright came up with a pretty good mod tire set up. I ran it tonight and I have to aggree, that it just might be a little quicker then previous set ups. Or at least it may or may not work better at your track. Again; Parma Pink rears and now Magenta fronts are my tires of choice. They have good contruction, strong with out breakage, durable, consistant traction, reliable bearing seats, just "good tires"! With the magentas, you need to remove the side springs from the tubes or you will have way too much steering. I / we also went to 0.022's in front instead of 0.020's. The car turned in more aggressively off power and closer to the corner then with the other set up. I often would clip the dot due to the extra turn in. How much faster was it? Well I was not able to beat the track record that I hold with the old set up, but I blew the main time out of the water. So a bit of a push. It's nice to know that you can have more then one set up that is fast.
See you all at the 'birds!!!!
Brian; slapmastertools.com
Slapmaster6000 is offline   Reply With Quote
Old 02-03-2005, 12:48 AM   #157
litespeed-dom's Avatar
Default Re: Tire update
slapmastertools.com
Brian, front page looks awesome already!
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 02-03-2005, 06:32 AM   #158
Hi Brian,
Thats an interesting set up, I will have to try that. I tried magenta's with white and it was ugly. one problem I did find with magenta's - even though they do start off withia lot of traction, they get MORE grippy as the race goes on. I found by the 6th minute it was undriveable. What did you think?
Chris
Old 02-03-2005, 11:41 PM   #159
Default magenta grip
They don't fool around. They corner hard. So hard, it made me wonder about bat/motor efficiency (sp). If you have the equipment to push that set up, I think that it's faster through the course. I think that the pink/purple with springs is more efficient. But I would expect that at the top level, that you will need to come out swinging. This set up was: scream up to the corner just a foot short, pull it around, and ripp it back to life. It's likely that you will out corner many cars with this set up.
I just got delivery of my shirts tonight. They look awesome! I will drop some pic's
Brian; www.slapmastertools.com
Old 02-03-2005, 11:42 PM   #160
Default shirts
Look: you too can look fat and happy in a new stylish Slapmaster Tools t!
Old 02-03-2005, 11:47 PM   #161
Default Alvin's paint job
This is the body that I will be using in mod at the 'birds. Alvin Nucume painted this amazing Speed 12 up for me. I am very thankful for his attention to detail and dedication to local racers, so that we can race in style. Thanks Alvin!!!
Old 02-06-2005, 09:12 PM   #162
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Default Re: Alvin's paint job
Alvin That is an awesome paint job...
Ya like mine monkey slapper paint job ?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 02-06-2005, 10:11 PM   #163
dakrat's Avatar
all i can say is WOOOW!
dakrat is offline   Reply With Quote
Old 02-06-2005, 10:22 PM   #164
Hi Brian,
I tried one more time to get the purple's and whites to work to not much avail, I can't get the corner speed i want so I will try your magenta setup, but I think I'll try it with magenta's and Blacks. I found blacks to be very similar, but not quite as aggressive. I did get a QC2 in the car and i like it a lot. I ran a 10x2 and raced it strapped without dumping, I hit full throttle for the whole race even in the infield.
Chris
Old 02-07-2005, 11:46 AM   #165
Default Out of the Office
Or I should say that I will be in the office doing field research! ha! For those that have order questions or need product, I will be in Orlando Florida for the Snowbirds race and will return Feb 14th. To my knowledge, I should have 3 cars running in the GTP Stock class and as many as 3 in the GTP Modified class by the hands of some fairly talented drivers. So we'll see when the dust settles. Keep an eye on the Snowbird site for Brian Bodine, Andrew Cartwright, Sean Maybell, and Trav Schreven.
Slapmaster MS 2.3 1/12th scale harjo R/C Items: For Sale/Trade 4 01-09-2008 03:24 PM
12th scale MS2.3 Slapmaster fjm9898 R/C Items: For Sale/Trade 4 07-29-2007 10:59 AM
Slapmaster MS2.3 12th scale fjm9898 R/C Items: For Sale/Trade 17 06-30-2007 06:06 PM
SLAPMASTER MS2.2 1/12th scale nhra6849 R/C Items: For Sale/Trade 16 12-26-2006 12:55 PM
Slapmaster MS2.3 12th scale stumper1 R/C Items: For Sale/Trade 11 09-03-2006 02:28 PM
