LIPO battery fitment into m05 and m06 >
Old 10-15-2011, 03:49 PM
Default LIPO battery fitment into m05 and m06
hi guys,
just a quick question...
i've got a m05 and m06 on the way...
need a battery..,
thinking of this lipo..
Turnigy 3800mAh 2S 7.4v 25C hardcasepack
anyone know for sure it it will fit both chassis? its meant to be 136x45x22mm w/ bullet connectors... i know i will have to buy bullets for the car to connect, but aside from that, is it all good?
otherwise, i'd get a 3800 nimh here:
ebay ref: 180735882478
from what i understand, the lipo will be a bit quicker due to 7.4 vs 7.2v and it will maintain its voltage and power output longer than nimh? true?
if so i would probably pop for the lipo, otherwise at the same rating the nimh is the go as its a bit cheaper and the weight difference isn't much due to the lipo's hardcase ~ 50g.
cheers
joe
wankski is offline
Old 10-15-2011, 04:06 PM
Do you want the good news or bad news first.
Good news is that a squared off battery will fit the M-06.
The bad news is that you need a rounded battery like a NiMH stick pack for the M-05 or hack the chassis to fit the squared one.
AreCee is offline
Old 10-15-2011, 08:37 PM
ahh thanks very much AreCee!
that's ok - i'll probably go for the nimh first, then upgrade later if i feel the need..
is there any guide as to what dimensions of pack will fit a m06 and m05?
i assume a 132x45x24mm 7.2v nimh will be no issue (w/ tamiya connector)
but is there anywhere with a guideline as to max dimension for each chassis?
the tamiya instructions are silent on battery aside from "needed, tamiya battery" - gee thanks!!
couldn't bring up anything useful aside from specific packs using the search...
cheers!
wankski is offline
Old 10-15-2011, 08:43 PM
BrodieMan's Avatar
Team Orion Rocket Packs will fit perfectly
http://www.horizonhobby.com/Products...rodID=ORI14107
BrodieMan is offline
Old 10-15-2011, 08:45 PM
Rob B99's Avatar
Trader Rating: 15 (100%+)
the orion rocket pack 3000 fits the m05 ... also peak racing makes a power-flo pack that fits . the are both lipo and shaped with the round edges to fit the m05 ..
Rob B99 is offline
Old 10-15-2011, 09:12 PM
There are quite a few rounded packs but the OP was asking about fitting the squared HK pack.
I have several rounded packs just for my M-03 that work well with a silver can. Would I be able to use my IP3800 in it, no way. The M-05 is almost the same.
If you want to save a few dollars look at the Duratrax line of lipos.
AreCee is offline
Old 10-15-2011, 09:29 PM
thanks AreCee, that's what i'm looking for....
and what dimensions fit? i think someone told me that for the m03/5 134mm max?
wankski is offline
Old 10-15-2011, 09:51 PM
Whatever length a NiMH stick pack is. I guess it's about 135mm or so.
http://www3.towerhobbies.com/cgi-bin...&P=SM&I=LXAAGG
http://www3.towerhobbies.com/cgi-bin...&I=LXYDA3&P=SM
AreCee is offline
