Old 11-25-2004, 08:04 PM   #1
Leester's Avatar
Trader Rating: 21 (96%+)
Tips on sanding Rubber touring tires for carpet
hi guys. do you have any tips on how to sand or scuff rubber touring tires for carpet? I have a tire truer but I will not use it for trueing rubber tires, just scuffing them. Thanks!
Leester is offline   Reply With Quote
Old 11-26-2004, 03:47 AM   #2
pink pac man's Avatar
i think you can get a sanding drum for tire truers
pink pac man is offline   Reply With Quote
Old 11-26-2004, 05:32 AM   #3
i just got a sanding block, one of the molded ones, and juts lightly pressed it against the rotating tire, just enough to get the crap off them and reveal the fresh rubber, worked a treat in japan for F1.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 11-26-2004, 07:30 AM   #4
Leester's Avatar
cool where can i get one? and what type of material do you use to sanding the tire with? sanding paper? scoch brite?
Old 11-26-2004, 01:29 PM   #5
By sanding the tires, do you mean to sand it down or just to sand away the dirt that's picked up by the tire. I've heard people sand the middle of a rubber tire to get rid of that seam in the middle. I've been told it's suppose to give better traction. I just want to clarify this. Thanks
Asurada Sugo is offline   Reply With Quote
Old 11-26-2004, 02:01 PM   #6
Leester's Avatar
i all i'm trying to say is just sanding the tires down. for example sanding away the parting line. Thank you!
Old 11-26-2004, 02:50 PM   #7
I've seen an expert at my local track just use a piece of sand paper folded a few times and send the parting line using the thickest folded edge of the sand paper.
I guess that's the simplest and cheapest way to do it!
Old 11-26-2004, 04:20 PM   #8
Essnowyt's Avatar
Send a message via AIM to Essnowyt
I have been using isopropyl alcohol on my rubber tires to clean them. It works great and itís cheap. True, sanding might be better, but I donít have a tire truer. Just another idea.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 11-26-2004, 05:09 PM   #9
TeamButter's Avatar
Send a message via AIM to TeamButter
Yokomo makes a rubber tire "tuer". It is used for removing the bead off a new rubber tire. Hope this helps.
Mike A.
Teambutter
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 11-26-2004, 07:35 PM   #10
Speedie's Avatar
Lee the few times I tried it I uses 220 grit sandpaper and then some scotchbrite after that to smooth them out. Thats what worked best for me.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 11-26-2004, 08:18 PM   #11
Leester's Avatar
Thanks guys! You are a big help!
Old 11-26-2004, 08:25 PM   #12
Leester's Avatar
Mike A.
Teambutter
No worries my friend . have a Integy tire truer which I will be using a tire sander as well as foam tire truer. Thanks!
Old 11-26-2004, 09:13 PM   #13
Trader Rating: 2 (75%+)
I use a Emory board to scuff my rubber tires........found this at my local HobbyTown also they do come in different coursness.
PUNISHER is offline   Reply With Quote
Old 11-26-2004, 09:33 PM   #14
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Lee,
How's it goin?
For the CS-27's, we were just sanding away the parting line using a folded piece of sand paper, then lightly go over the whole tire just to remove the glazing ( the "shine" on the tire ). After that I just use the scotch-brite pads to clean up the tire.
It just helps the tires come in faster for the first couple of laps, instead of taking 2 laps to "come in" like they do at Trackside.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 11-27-2004, 05:56 AM   #15
GTO2's Avatar
R/C Tech Charter Subscriber
Rubber tyre sander..click my siggy. some info inside as well (aka Sandstorm).
driftercentral.com
GTO2 is offline   Reply With Quote
Touring Carpet Season: foam or rubber tires? ShaunMac Georgia Racing 69 03-09-2012 01:31 PM
Tips for chassis sanding hierog Electric On-Road 30 08-13-2007 09:02 PM
Best touring car for rubber tire on carpet racing? rccars4scott Electric On-Road 0 09-18-2006 04:55 PM
Rubber Tires On Carpet thecrow2k Electric On-Road 5 10-20-2005 07:42 PM
Rubber tires on carpet? TC3er Electric On-Road 22 03-10-2004 09:06 PM
