Old 10-13-2011, 11:14 AM   #1
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Default Formula to calculate belt length for custom gearing?
Is there a formula to calculate belt length for custom gearing? I am building a drift car to play with between off-road and on-road racing.
The car is an XRAY FK05 with 34/20 pulleys on the rear and a 180mm belt. I am going to 34/26 pulleys and would like to find a belt the correct size rather than making a tensioner, if possible. Thanks.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 10-13-2011, 02:09 PM   #2
mingnon's Avatar
have a look at post 3, hope it helps
http://forums.radiocontrolzone.com/s...d.php?t=120475
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 10-13-2011, 02:11 PM   #3
HB Moose's Avatar
You need 3 more teeth on the belt. (26-20)/2=3 because the belt will be covering 3 more teeth on the pulley and have the same distance between centers. I forget how the belts are specified but that will make it 9mm longer around.
Bruce "Moose" Riedinger
HB Moose is offline   Reply With Quote
Old 10-13-2011, 02:12 PM   #4
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
The belts are 3mr pitch so for every tooth it's 3mm in length so 180 mm belt divide by 3 = 60 , so do the pulleys you want take a string and wrap it around , mark it then measure the total mm's then divide it by 3
Old 10-13-2011, 06:02 PM   #5
Yeti AS3's Avatar
Perfect! Thanks a bunch!
Hot Bodies D413
AE B5m
