Old 10-09-2011, 12:23 AM   #1
Thumbs down hpi sprint 2 flux throttle questions
I have a couple of questions for some experts out there...
I have to pull throttle almost all the way back so the car could star moving and this car is brand new, and the throttle trim is set up where the car almost moves before I pull the throttle, but when I pull the throttle just a little the car rattles before it actually moves smoothly.... What can I do to repair that or is that normal? Please help...
jpsearch is offline   Reply With Quote
Old 10-09-2011, 02:34 AM   #2
you gotta reset the speed controller, nothing to do with the radio. You have to follow the instructions and do it once again then it will work.
Hoomark is offline   Reply With Quote
Old 10-09-2011, 01:53 PM   #3
Default hpi sprint 2 flux throttle questions
I don't think the problem is with the speed control, because If I try to manually rotate
the spur gear, it feels rough and you have to actually rotated it hard to begin rotating the motor, it seems like this brushless motor has a lock up when it first starts to move, the reason I'm saying this is because I actually removed the spur gear and rotated the pinion gear with my hand and if you turn it slowly it feels like there is something holding, so thats probably why when I accelerate the car won't move right away and it gets even worse backing up. I wan't to know if every hpi sprint 2 flux does this same thing?
