Old 12-20-2011, 02:50 PM   #436
CypressMidWest's Avatar
Originally Posted by al dente View Post
of all the people that need one...........
Nash needs one for the bottom of his car. It would soften those horsepower induced chassis slaps against the driver's stand.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 12-20-2011, 05:08 PM   #437
For_the_win's Avatar
All i need to do is get tires, servo, and mount the body.
For_the_win is offline   Reply With Quote
Old 12-20-2011, 08:13 PM   #438
Tempest2000's Avatar
Trader Rating: 21 (100%+)
Dirla's car doesn't need a bumper. It needs a roll cage and airbags
Tempest2000 is offline   Reply With Quote
Old 12-20-2011, 08:26 PM   #439
hanulec's Avatar
Trader Rating: 27 (100%+)
+1
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-20-2011, 10:55 PM   #440
WORD UP Skeen, WORD UP!!! He's the fastest guy I've ever seen for 7 mins. 12 sec. The other 48 sec. He's pretty scary......
Old 12-21-2011, 09:01 PM   #441
markiemark's Avatar
Trader Rating: 23 (100%+)
Just wanted update on my spur gear issue. After trimming the spur and still gritty. I keep rebuilding it couldn't get it. Bearings felt good but I replaced them just to see and bam butter smooth again. Feel a little dum now
~ ~Blue Diamond Park Raceway~~
~~~~D Main Champ~~~~
markiemark is offline   Reply With Quote
Old 12-22-2011, 02:29 AM   #442
WIITA's Avatar
Trader Rating: 42 (100%+)
The bearing that takes the load on the outside can be tricky.
Team CRC / Sanwa / Team scream / Genesis RC / Hobbywing / TQ Wire / Schelle / MIP / RC^2 / TEKNO / BoomRC
WIITA is offline   Reply With Quote
Old 12-22-2011, 10:40 AM   #443
if you can abide the price of entry, the slapmaster thrust bearing will eliminate your outer diff bearing troubles for good. admittedly their thrust bearing is a little pricey. but once that one time investment is made, crunchy diff action will be a thing of the past. and a tip (if you ever do decide to pick up a slapmaster), I run mine with flat side of the little rings (not the side with the groove machined in) facing towards the captured balls thrust bearing itself. The diff spins more free that way and yet it still seems to stay smooth indefinitely.
vafactor is offline   Reply With Quote
Old 12-22-2011, 11:31 AM   #444
nashrcracer's Avatar
R/C Tech Charter Subscriber
that's when I nod off napping....
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 12-22-2011, 04:04 PM   #445
markiemark's Avatar
Im look into the slap master setup next. But first i gotta figure out which new motor im going get that seems be a task with all the ones out there. So far either a thunder power, speed passion v3 1cell , or a duo 3. choices choices.
Old 12-22-2011, 05:12 PM   #446
lots of guys here are liking the revtechs.
Old 12-22-2011, 05:20 PM   #447
greywolf74's Avatar
Trader Rating: 15 (100%+)
thats true
greywolf74 is offline   Reply With Quote
Old 12-22-2011, 05:37 PM   #448
markiemark's Avatar
Alot of the revtechs around here are having bad sensor board problems so wanna pick something thats not 50/50
Old 12-22-2011, 05:40 PM   #449
Duo 3 then, or orion.
Old 12-22-2011, 06:32 PM   #450
markiemark's Avatar
Track has a couple orions in just havnt heard much on here about them and with the 110 price no one local i see runs them. are the worth it over the duo 3?
