New CRC Gen Xi 12th car..... >
Old 12-12-2011, 07:55 AM
  #376
Default tweak?
Originally Posted by Still Bill View Post
Sounds like either toe-out or tweak.
What is your front toe-out? Try the wheels with zero toe.
Do you have a method for determining tweak issues at the front and rear of the car?
Bill
How do you tell if the tweak is in the front or rear??
I have often wondered about that.
Just getting my xl dialed in, made some improvements at our last race-
will not have a track again until after the first of the year.
thanks--srrc
SrRC is offline
Old 12-12-2011, 08:30 AM
  #377
CypressMidWest's Avatar
Originally Posted by Kenny L View Post
Personally I like alot on the Xi something I didnt run as much on the Xl actual measurement is 3.5mm. Also for myself the droop tends to make it less edgy maybe cause I don't lift but thats me and how I drive.
Yeah, It works well for your "fully-strapped" driving style. You're definitely fast that way.....
CypressMidWest is offline
Old 12-12-2011, 11:06 AM
  #378
Trader Rating: 46 (100%+)
thanks--srrc
http://www.markpayneblog.blogspot.com/
This is a great place to answer that question.
biz77 is offline
Old 12-12-2011, 11:46 AM
  #379
kingbee9's Avatar
Trader Rating: 30 (100%+)
ran my Xi inline with the shorty pack this weekend. all i can say is SWEET! it was by far the best handling car i've ever driven. the corner speed was for more than i was used to. very easy car to drive.
kingbee9 is offline
Old 12-12-2011, 12:34 PM
  #380
Kenny is definitely fast. I can attest to that on a weekly basis, usually a couple of times each week lol! I feel very lucky to be driving with and learning from him so often.
Cowarn is offline
Old 12-12-2011, 02:05 PM
  #381
Trader Rating: 38 (100%+)
That is exactly what I thought of mine with the inline shorty setup. I'm hoping with a few minor tweaks to catch to top guy at the track, only off by 6 seconds or so yesterday in my second qualifier....which happened to be the third time I drove the car with this setup.
linkless is offline
Old 12-12-2011, 04:15 PM
  #382
WIITA's Avatar
Trader Rating: 42 (100%+)
So Now that a lot of guys have the shorty packs. Whats everyone finding that works for them setup wise?
WIITA is offline
Old 12-12-2011, 04:25 PM
  #383
kingbee9's Avatar
.50 springs in front
around .5mm droop in front
gold associated center spring
red side springs
.5* camber in front
magenta/magenta
30wt. in the shock
30,000 in the damper tubes
decent amount of pod droop
3.75mm ride height
10* caster with all 3 shims back
30,000 on the king pins
speedo directly in the center of the car in front of the battery. the servo was moved forward, left ear trimmed off and moved to the left bulkhead then shoe-gooed flat. the car was balanced which put the weight on the front tires in the 140-148 gram range
pretty basic setup, nothing special for my car. i have the pod with the shock in the normal position but have the old plate on the left side, the swoopy one to box in the pod.
that's what i ran this weekend on medium grip carpet, it was a new layout that we hadn't run before.
hope that helps you
kingbee9 is offline
Old 12-12-2011, 09:58 PM
  #384
Ray k's Avatar
Trader Rating: 47 (98%+)
Default FYI
False alarm !!! FYI on my new shorty !!
If anybody is using the spring barrel type 4mm connectors ,not the castle solid one . I had some inconsistent charging issues ,because the hole in the battery case is a little undersized .Causing contact problems for charger and car . Simple fix is to ream the plastic out to match the interior connector. Just a little twist of body reamer !
Ray k is offline
Old 12-13-2011, 07:49 PM
  #385
Toe is set about .01 out and rear tweek is really even. Front is about 1 ounce differenet right being heavier.
Bill
Fireball10 is offline
Old 12-15-2011, 08:17 PM
  #386
Trader Rating: 24 (100%+)
What is the weight difference between the CRC 5600 65c and the new CRC 1s short 4200? Thank you
sstretch is offline
Old 12-15-2011, 11:03 PM
  #387
For_the_win's Avatar
The 5600 is a full sized 1s lipo while the 1s shorty is the new small version.
For_the_win is offline
Old 12-15-2011, 11:22 PM
  #388
Still Bill's Avatar
Weight, weight, weight...LOL
Still Bill is online now
Old 12-15-2011, 11:41 PM
  #389
And 1400 mah......
Hell, I remember when 1400 mah was the maximum capacity of the cells......
Old 12-16-2011, 09:58 AM
  #390
And 1400 mah......
yeah me too but 1400 mah wont make a difference if the c is around 40
