New CRC Gen Xi 12th car..... >
Old 12-07-2011, 02:00 PM
  #346
For_the_win's Avatar
Sweet I just got it and i looked through the box, and wow!! The quality is insane! Ill be doing pics while i build it.
For_the_win is offline
Old 12-07-2011, 02:30 PM
  #347
Kenny L's Avatar
Trader Rating: 16 (100%+)
http://www.racerlog.com:8087/wiki/CRC_Gen_Xi
Just did few small updates
Kenny L is offline
Old 12-07-2011, 03:35 PM
  #348
While everyone else is building and playing with there Xi's I've just been able to start building my XL, that has been sitting on the shelf since last march. Does any one remember what shock oil, front spring and tube lube come with the kit. Kit came with red shock spring and white side springs. That's what I currently have on my GenX. The top of the lube bottle is red. I have red, blue and white lubes can anyone tell me what weight they are, also is there a baseline set up for the XL. I hope to race it sunday, my Xi upgrade kit and R8 bofy are on the way. I will be racing 1S 10.5 With Tekin RS pro. Thanks for any help!!!!
THEBIGBULL is offline
Old 12-07-2011, 03:48 PM
  #349
Kenny L's Avatar
lube is the crc light wt doesnt have wt to it believe it's like 5k ish. The oil in kit is 30wt. As far as setup my champs Xi setup should work great on Xl is pretty much same as I ran with my Xl but run battery in rear position
Superstock
CRC Gen-Xi
Body: CRC Black Art Audi R8C
Front Tires: Crc magenta 40.75mm glued face
Rear Tires: Crc Grey low 42 mm
Batteries: inline
Front H Brace
Front springs: .50
Caster: 10 degrees with shims 1 forward two back
Camber: 1/2 degree
Side springs: whites 2 from all way out & tweaked
Center shock spring: red
Center shock oil: 30wt
Dampner oil: Losi 50000
Front ride height: 3.5mm
Rear ride height: 3.5mm
Center ride height: 3.25mm
droop: tons use wgt shock end
Angled mount for servo
Kenny L is offline
Old 12-07-2011, 03:51 PM
  #350
http://www.teamcrc.com/crc/downloads...09IICsetup.pdf
Start with this setup.
Red cap is 1k
White cap is 3.5k
Blue is 10k.
Car comes with 30 wt oil. That is what we all use. The front springs are .50. Start with them. If you need more steering, you can go to .45. The red spring in the kit is the same as the gold spring on the setup sheet.
dumper
dumper is offline
Old 12-07-2011, 06:10 PM
  #351
hanulec's Avatar
Trader Rating: 27 (100%+)
Kenny - the setup is now readable at http://racerlog.com/wiki/CRC_Gen_Xi
hanulec is offline
Old 12-07-2011, 06:17 PM
  #352
Kenny L's Avatar
Thanks dude
Kenny L is offline
Old 12-07-2011, 06:55 PM
  #354
haywood's Avatar
Trader Rating: 49 (100%+)
Smile Northstar Classic
I have been getting reports of an old Carpet Knife beating the new xi shortys up in Dakota last weekend. Are those reports accurate?
haywood is offline
Old 12-07-2011, 07:23 PM
  #355
Trader Rating: 38 (100%+)
The short batteries are so cute I almost don't want to put them in the cars. :-)
linkless is offline
Old 12-07-2011, 09:12 PM
  #356
Hey Kenny, life pack or booster and why?
Old 12-07-2011, 09:20 PM
  #357
RacinJ's Avatar
According to this post, it's true.
http://www.rctech.net/forum/10000423-post92.html
Congrats Mitch!!
Wish I'd been there.
RacinJ is offline
Old 12-08-2011, 10:43 AM
  #358
Castradamus's Avatar
Trader Rating: 54 (100%+)
I have a Gen XL which will be converted to Gen Xi some time next week. I wanted some feedback on the the rear pod. My car does not have the standard pod setup which would be:
low pro. motor plate, plastic micro left pod plate and standar upper pod plate
It appears that everyone is running this setup in 17.5 blinky. I see there is an option for a 4 mm upper pod plate and also a full box rear. Which is better?
Castradamus is offline
Old 12-08-2011, 11:02 AM
  #359
I am not sure what a "standard" rear pod is.
If you have a GEN XL, then you already have the brushless specific rear pod, which works fine. We made the boxed in rear pod for those people that thought they had to have it. We made the 4mm top plate for those people that had problems breaking the regular thickness top plate. Neither of these are mandatory. If you took a look at what the team guys are doing, you will see a mixture of stock pod, boxed in pod, stock pod with aluminum leftside pod plate, and a couple with the 4mm top plate. They all work. I personally use the box stock rear pod with the plastic leftside pod plate on my 17.5 car, the stock pod with aluminum leftside on my 13.5 car and a boxed in pod on my WGT.
I hope I did not confuse you.
dumper
dumper is offline
Old 12-08-2011, 12:51 PM
  #360
What size is that .082 drill bit? is it a 1/16?
