Old 01-08-2007, 06:41 AM   #1456
proceed5's Avatar
Originally Posted by VooDooPH
on an added note, reading through some of the other battery charging threads here, it seems that its not a good idea to run fans while charging my batts. i live in a hot, humid and tropical country so afternoons can get pretty nasty especially during the summer. would it still be a good idea to run fans while charging my IB4200s? Says it increases internal resistance of the bats. I'm currently set at 6A @ 6mV delta. Or should i run the fan blowing away from the battery instead?
Thanks!
Hi VoodooPH,
The muchmore HeatsinkII which connects to the CTXC's output ports are good for hot and humid weather conditions. There are 6 fans on the HeatsinkII placed 3 above and 3 below the Aluminum heatsink, all blowing outwards direction.
I have been using these HeatsinkII's on both my CTXC's each time I charge. Cheers.
proceed5 is offline   Reply With Quote
Old 01-08-2007, 09:06 AM   #1457
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
hi proceed5,
thanks for the tip. noticed your fans are blowing away from the batt... maybe that's what i'm doing wrong (i have a pair of 80mm fans blowing at the batts during charge). i'll try to get a heatsink for better heat dissipation (looking at the Atlas heatsink that doubles as a battery soldering jig). btw, what temp does your batts peak at?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 01-08-2007, 09:16 AM   #1458
I bought one of those Battery HeatSink2 dealies also.. not impressed with the price.. but very impressed at how quickly it brings battery temps down.
mcgmark is offline   Reply With Quote
Old 01-08-2007, 03:48 PM   #1459
Hello All,
Just looking to buy a used (but good condition) CTX-C. Anyone selling? If so how much? send me a pm.
Cheerz
Obsidian is offline   Reply With Quote
Old 01-08-2007, 03:52 PM   #1460
Casper's Avatar
Trader Rating: 34 (100%+)
Check the F/S trade section here. I have seen a couple go for around $130.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 4.0, TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 01-08-2007, 11:07 PM   #1461
proceed5's Avatar
hi proceed5,
Hi VooDooPH,
Yes correct, The HeatsinkII's fans standard from the factory blows away from battery. Generally, my batteries peaks at 42C-46C. Cut off Temp 48C. Fan starts 40C.
Suggest you purchase the Muchmore HeatsinkII. The HeatsinkII is effective & dissipates heat fast, plugs straight into the Cell Master Charger and allows pre-set operating parameters.
As for other types/brands, no doubt the fans works, but fans are On all the time, whereas the HeatsinkII will operate at the Temp Start programmed n controlled by the CTXCharger.
Cheers
Old 01-14-2007, 04:39 AM   #1463
VooDooPH's Avatar
Li-Po charging on the CTX...
was able to get a VRX Stylus bat pack for the M8. Its 800mah and 3-cell. Do I just punch in "3 cell" and charge at .8A? The CTX will know when the pack is full and will shut down on its own?
asking the questions coz i noticed the li-po charging feature doesnt have the other set parameters available to NICD and NIMH charging.
Thanks!
Old 01-14-2007, 04:44 AM   #1464
VooDooPH's Avatar
Originally Posted by proceed5
Hi VooDooPH,
Cheers
was able to get an Atlas heatsink with fan (doubles as a battery jig which i find neat ). But the fans blow at the heatsink not away from it. I'm thinking this is fine since the air from the fans don't hit the batteries in any way anyway.
was also able to make a make-shift connector for the side terminal with old female servo connectors. now i can set the fans to go on a specified temp (right now set at 45 with cutoff at 50).
the combo is good alternative to the MM HeatSink II, imho. Don't get me wrong, I'd love to get my hands on the MM stuff (all for the love of bling) but I have a wedding to save up for.
Old 01-14-2007, 10:51 AM   #1465
Nexus Racing's Avatar
Thanks!
Yes, .8A and 3cell is all you need to input, and it will safely charge your pack.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 01-14-2007, 11:36 PM   #1466
VooDooPH's Avatar
ok. thanks! tried it but it says ".7A" when charging (eventhough i entered ".8A")... is this normal?
Old 01-15-2007, 06:51 AM   #1467
proceed5's Avatar
Great VooDooPH, great to hear that you have found an alternative that works.
Maybe you can try re-configuring your Atlas Heatsinks' Fans positions so that it blows away from the battery (that is, if you like the idea).
Yupe, I understand very well what's its like to charge under Hot and Humid weather situations.
Cheers & good luck
Old 01-20-2007, 07:26 PM   #1468
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Can anyone tell me the RPM of the fans in the cellmaster?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 01-20-2007, 10:07 PM   #1469
VooDooPH's Avatar
Cheers & good luck
tried them out during the club race yesterday. early in the day (we started racing a bit after noon), and my packs were temp cutting at around 4400mah (on IB4200WCs, 50deg temp cutoff). with 3 packs, i started with 45deg as the trigger point for the fans. then 42deg, then 40deg. it was only the last pack that didn't temp cut (peaked at 4600mah, 3mV) but it was late in the afternoon already with the temperature much lower). i'm keeping my fingers crossed that the temp wasn't too high and that i didn't damage my cells... they're kinda new.
Old 01-21-2007, 03:45 AM   #1470
R/C Tech Charter Subscriber
Default Fan RPM
Hi,
The fans in the CM are 12,000rpm at 12V.
Thanks,
keithander is offline   Reply With Quote
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 08:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 06:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 03:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 11:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 05:37 AM
