Old 12-29-2006, 12:31 AM   #1426
Runin Ronin's Avatar
Originally Posted by tcharger
Im hoping soomeone can help me out, I acquired a tekin titan esc and there is an extra wire coming out of the front where the receiver wires come out. I have the manual and it doesnt mention the wire. Anyone know?
FET Servo wire???
Runin Ronin is offline   Reply With Quote
Old 12-29-2006, 01:46 AM   #1427
Tek Nickal's Avatar
Wrong thread but its probably a FET servo wire, needed for servos that require 7.2v to operate. You can make sure of this by taking a multimeter, measuring between that wire and the negative wire coming off the servo or the battery. (someone correct me if I'm wrong).
Tek Nickal is offline   Reply With Quote
Old 12-29-2006, 09:14 AM   #1428
freekthefreak's Avatar
Originally Posted by ngo8
if youre charging 4200 WC cells start at 6 amps at 06 deltapeak temp cut off 48c mah at 5000 and you will be ok but before you charge youre pack make sure you equalize them 0.9v per cell and you are set .
i'm have the SHV cell's
at what rate should i charge them ?
freekthefreak is offline   Reply With Quote
Old 12-29-2006, 12:36 PM   #1429
Default Temp Charging
I've read the manual but must be doing something wrong anyway. What I really want to do is temp charge at 6 amps until the batteries reach 45 degrees C. As I understand it, that can only be done in CTX mode.
I've set step 1 to charge at 6 amps for 100 mA, step 2 to charge at 6 amps for 150 mA and originally set the temp cut-off and the voltage cut-off to 45 degrees F and 0.03 respectively.
With those settings, the charge cut off by the peak detect with a temp reading of well below 45 degrees C. So, over the coarse of the day I moved the peak detect up to 0.14 in an attempt to achieve a temp cut-off. When I got to 0.14, the unit continued to charge even after 45 degrees C was surpassed.
What am I doing wrong? As I said, all I want to do is charge my packs until the temp reading is 45 degrees C. If it matters, all of the packs are 6-cell and all were discharged to 5.4 volts prior to starting the charge. Thanks.
Stroker Ace is offline   Reply With Quote
Old 12-29-2006, 12:39 PM   #1430
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
is there a way to adjust how bright the back-lite display on the MM -ctx charger ?
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 12-29-2006, 04:17 PM   #1431
Nexus Racing's Avatar
CTX charge is not neccessary to do this. All you have to do is initiate a regular "peak charge" (linear charge) at 6 amps, turn the delta peak all the way up (99 I believe), and set the temp cut to 45 deg .
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 12-29-2006, 04:19 PM   #1432
No.
NEXUSRACING.com
Old 12-29-2006, 09:45 PM   #1433
hey man order from nexus beacuse if you get youre muchmore stuff form overseas and it breaks they wont service youre stuff here in north america for some reason , i know its cheaper from hong kong but buy youre muchmore stuff from here you will thank me in the long run plus arun from nexus is an awesome guy .
I got a used ctxd from here on R/C tech swap and sell how do i tell if was sold in the US or over seas. Let me know it needs to be sent in for repair.
gotyournumber is offline   Reply With Quote
Old 12-29-2006, 10:40 PM   #1434
Thanks Nexus, works just like it's supposed to.
Old 12-30-2006, 12:31 AM   #1435
Arun's Avatar
If it is a US unit, then it will have a silver sticker on it indicating so.
Sometimes we have also noticed different languages on the internal components.
No problem .
http://nexusracing.com
Arun is offline   Reply With Quote
Old 12-30-2006, 01:22 AM   #1436
No problem .
great mine has that sticker.
Old 12-30-2006, 11:53 AM   #1437
ralph m's Avatar
Trader Rating: 31 (100%+)
Default lithium charging
Can someone provide the charging specs in the lithium mode?
I understand that there is a 1 amp limit (I'm only using this for tranmitter packs) but my Cell Master appears to limit the current as the cells reach capacity; down to .1 and .2 amp as I approach 12.3V on a 3-cell pack; what I assume to be the voltage cut on a 3-cell pack.
Is this "ramp down" normal in the lithium mode or does my charger require service?
Thanks,
Ralph
ralph m is offline   Reply With Quote
Old 12-30-2006, 03:54 PM   #1438
Stein Tumert's Avatar
Thumbs up
Thanks,
Ralph
The Team Orion Advantage charger does the same. At least on that charger it is supposed to be that way according to the manual...
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 12-31-2006, 11:58 AM   #1439
Default Charge Error
I just had a charge terminate, the blue light is blinking twice per second and there is a message that says SUP on top row just to the left of the charge capacity number. What does SUP mean? Thanks.
Old 01-05-2007, 03:23 PM   #1440
sorry to dig up an old thread....
But i am trying some different things with my IB4200s.
Like on the SMC website they say to charge 4cell with a 5mv cut off per cell 20mv in total (0.02v delta peak) and for some reason i can't set the charger to 0.02, it either goes 0.00, then jumps to 0.03v, can anyone see if their cellmaster does this? as it is quite annoying
drivingpro is offline   Reply With Quote
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 08:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 06:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 03:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 11:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 05:37 AM
