Old 11-13-2006, 07:12 PM   #1306
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Originally Posted by EAMotorsports
www.nexusracing.net has a full page of charging instructions. The CTX-D Peak detect of 03 would be similar ot .003 on a GFX....but not exactly a true conversion with they type of Super linear current it produces. I would start around 10-12 and a temp cutt off of 40-45 degrees Celcius. You want the packs to peak at around 120F when checking with an infared temp gun (your a gas guy so I KNOW you got one ).
EA
Thanks....question: did you mean 10-12 AMPS??? I have to unpack my temp gun
Another question, the website had this for charging:
GP3300-Nexus Racing-19t/Stock High Power Competition
Step 1
2650mA 7.0A
Flex off
Step 2
2680mA 0.2A
Flex off
Step 3
4200mA 6A (for more punch, increase to 6.5)
Flex off
Temp 50
delta peak 09
What's with all the steps?
I had set the charger for the "peak setting" the instruction said use the CTX-D charging mode for NICAD'S.
Thanks for the help in advance.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 11-13-2006, 07:33 PM   #1307
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Step 1
2650mA 7.0A
Flex off
Step 2
2680mA 0.2A
Flex off
Step 3
Flex off
Temp 50
delta peak 09
My fault...I thought Arun had updated his site...Guess I'll have to get on to him!!
Charge at 6-7 amps with a peak cutt off of 10-15 to start with. Set the temp to around 47 degrees C to start (I had to go convert that over to F...HAHA). At the end of the charge check with your temp gun and see if its around 120 degrees F. If not increase the cutt off till it gets there. The temp cutt off is just a fail safe to keep a pack from overcharging.
Hope this helps
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 11-13-2006, 07:39 PM   #1308
Nexus Racing's Avatar
No no...that's a GP3300 profile he pulled up. On the charging page, we recommend a linear charge for IB4200.
Carl, the step charging profiles worked very well on GP3300 and sometimes IB3800, but linear charging reigns supreme on the 4200's for sure!
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 11-13-2006, 09:58 PM   #1309
ngo8's Avatar
Send a message via ICQ to ngo8
so for the 4200s charge them on the linear mode? at 06?
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 11-13-2006, 10:33 PM   #1310
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
is it safe to adjust the delta peak higher just so that the pack peaks at the near the ideal temp?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 11-13-2006, 10:50 PM   #1311
XrayFK's Avatar
Yes.
XrayFK is offline   Reply With Quote
Old 11-14-2006, 01:20 AM   #1312
Yes, I recommend starting at 06 and bump it up if you aren't getting enough temperature. 6amp linear works well in a lot of situations.
NEXUSRACING.com
Old 11-14-2006, 01:21 AM   #1313
Runin Ronin, you've got mail. I have a quick question for you.
NEXUSRACING.com
Old 11-14-2006, 02:18 AM   #1314
What is the "right" peak temperature??? Is 50C too high?
Hugo is offline   Reply With Quote
Old 11-14-2006, 04:20 AM   #1315
VooDooPH's Avatar
same question i guess... mine's currently set at 45deg but i live in a hot tropical country
Old 11-14-2006, 06:05 AM   #1316
Thank you EA and Nexus for the explainations.
Old 11-14-2006, 09:08 AM   #1317
Nautilian's Avatar
What temps would you be looking at using a temp gun on the IB4200s and the GP4300?
Nautilian is offline   Reply With Quote
Old 11-14-2006, 09:10 AM   #1318
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
Around 120F is the ideal temp for packs
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 11-15-2006, 01:04 AM   #1319
Like A. Rhodes said, 120 deg (48-49 deg C) is an ideal peak temp...after charge, the battery temp will rise closer to 130 deg, which is spot on for IB's.
No problem, Carl .
NEXUSRACING.com
Old 11-15-2006, 06:46 AM   #1320
What are the differences between the cell master and the cell master v1.0?
Thanks...
visit Hurricane Motorsports: www.teamhurricane.net | RCAmerica www.RCAmerica.com | HUDY | JACO
bigdog xxx-s is offline   Reply With Quote
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 08:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 06:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 03:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 11:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 05:37 AM
