Old 11-01-2006, 12:21 AM   #1261
I've just acquired 3 packs of Orion's IB4200s WCe ....
I was wondering how you guys charge them? Is step charging good for long life of the cells or just charge with linear?
Thanks in advance
Ben.C is offline   Reply With Quote
Old 11-01-2006, 01:08 AM   #1262
I fine here in-stock Andy Moore and Marc Rheinard edition good price
http://www.racing11.net/shop/index.p...sort=1a&page=1
initialrays is offline   Reply With Quote
Old 11-01-2006, 01:55 AM   #1263
Nautilian's Avatar
Originally Posted by Nexus Racing
Nautilian, we recommend that you start with a lower delta peak, somewhere in the range of 06 to 10. If you find that your cells do not get up to temperature, then begin increasing the delta peak. You will often see people using higher delta peak settings in cooler weather.
Also, keep your temp cut around 48-49 deg C, as your batteries will be gaining heat even after charge.
Got it , I assume I then want the temperature of the battery to sit at around 48-49? Also do you have in mind what settings I should run on the GP4300's?
Naut
Nautilian is offline   Reply With Quote
Old 11-01-2006, 01:56 AM   #1264
BlueR1's Avatar
another good site. some pretty cheap items there
BlueR1 is offline   Reply With Quote
Old 11-01-2006, 02:26 AM   #1265
RocketRacer's Avatar
besides the screen and case, what are the differences between the std. cell master and the limited edition ones??
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 11-01-2006, 02:37 AM   #1266
Nautilian's Avatar
I have heard that it is just a cosmetic change, however I have heard some people say that they have done an upgrade to the charging software. I stand corrected.
Naut
Old 11-01-2006, 02:49 AM   #1267
do you have the std version Naut? what did you pay for it? how would you rate it? i am looking to buy a new charger and i don't know what to get?
RocketRacer
Old 11-01-2006, 03:01 AM   #1268
Nautilian's Avatar
Got the standard, I have placed an order for 2x MR Cell Masters, you looking at around $140 for the standard edition, $180 for the limited.
Here in South Africa, everybody swears by the Supernova Competition. I have had one, and thought it was the biggest load of junk this side of the equator. I love the Cell Master, it has so much functionality and is worth every cent. Not to sound like a wannabe, but if most of the top 10 in the world use the Cell Master, it has to say something about the product and quality.
Old 11-01-2006, 03:45 AM   #1269
BlueR1's Avatar
thats b'cause companies like duratrax and supernova dont sponser racers. anyway what was wrong with the supernova? i dont think the celmaster has anything over the supernova other than its smaller footprint.
Old 11-01-2006, 03:54 AM   #1270
Nautilian's Avatar
Screen would hang on mode change, it would shut down from overheating even though it was outdoor (not direct sunlight) and was about 26 degrees. Temperature sensor was out by +-10 degrees.
I took it in for repair/exchange only to get a report from the distributor saying that unit was in perfect condition!
Naut
Old 11-03-2006, 04:13 AM   #1271
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
anyone try using their cell master to "condition" their cells (using 1A discharge to .9V on each cell individually)? seems to be more accurate than using the CTX-D, though a bit tedious to do.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 11-03-2006, 08:13 AM   #1272
Casper's Avatar
Trader Rating: 34 (100%+)
Why do you think the cell master is more accuate then the CTX-D? It should have the same cutoff accuracy if not better then the cell master. Also that would take forever to discharge each cell down at 1A. If you think 5 amps is too high then get a smart tray. It equalizes at 2.7amps.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 4.0, TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 11-06-2006, 10:33 AM   #1273
TFR
TFR's Avatar
Early Christmas gift...
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 11-06-2006, 01:54 PM   #1274
rc-zombies's Avatar
gee thanks! you don't need to wrap mine..
Old 11-10-2006, 08:10 PM   #1275
Runin Ronin's Avatar
Just FYI... I have a couple Cell Masters for sale:
http://rctech.net/forum/showthread.php?t=136404
Runin Ronin is offline   Reply With Quote
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 08:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 06:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 03:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 11:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 05:37 AM
