Old 08-30-2006, 08:20 AM   #1156
Rob Phillips's Avatar
Charging profiles, Can I use the same profile for 4 cell that I used for 6 cell 3800's. If not, could some one post one up. Thanks
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 08-30-2006, 08:25 AM   #1157
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
You can if you dont have to set the number of cells like a Pulsar Competition 1/2, But on a Reedy Quasar Pro, you have to define the number of cells.
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 08-30-2006, 08:30 AM   #1158
I meant other that changing the number of cells in the profile. so I guess that's a go then, just change the number of cells and I'm good to go (doin the Taco Bell hand thing). Thanks
Old 08-30-2006, 10:04 AM   #1159
oracle's Avatar
Hi guys, i need some help with my Cell Master. I just got my IB4200 SHV and tried charging it with my Cell Master. Today is the 3rd time i charged it and it peak cut at 353mAH although i have fully discharged it with my Spintec Batt Manager. The first charge of the battery was at around 4300mAH, the 2nd charge was around 3500mAH and the 3rd charge at 353mAH. What's wrong?
oracle is offline   Reply With Quote
Old 08-30-2006, 10:11 AM   #1160
Casper's Avatar
Trader Rating: 34 (100%+)
List what your profile settings are. It is hard to tell what the problem is without knowing how the charger is setup up.
Check out the nexus racing site for recommended profiles
http://nexusracing.net/newsdesk_info.php?newsdesk_id=19
My guess is your lock out is not set long enough and your delta peak may be a little low.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 4.0, TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is online now   Reply With Quote
Old 08-30-2006, 12:14 PM   #1161
Nexus Racing's Avatar
A 15-20min long lockout should fix this. The spintec Batt Manager takes the voltage of the pack way down slowly...the end result is you have a very dead pack. Your pack probably just needs to get some charge into it before the voltage stops fluctuating.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 08-31-2006, 10:53 AM   #1162
oracle's Avatar
Thanks for your advice. As i read from the Spintec Battery Manager thread, i'm suppose to use the Battery Manager to discharge by battery after play and to equalize it before i charge again. Is this true?
Anyway, i'll try what you said tomorrow evening as i will be practising with my buddies. I just hope that my IB4200 is ok.
Thanks again
Old 08-31-2006, 11:27 AM   #1163
Casper's Avatar
The spintec is to be used for "maintaince" of the pack. I would not use it every time. It works great at making old packs "fresh" again but it really does not make good packs any better. I would only recommend trying the cells down to no less then .7V per cell and then charge from there. Every 5-10 runs of the pack use the spintech.
Old 08-31-2006, 01:54 PM   #1164
You can't make old packs fresh again,only new is fresh and once packs are old they are old.
Hyper1 is offline   Reply With Quote
Old 08-31-2006, 02:02 PM   #1165
Casper's Avatar
Sorry-- The spintec will make an old pack perform more like it did when it was new. Is that better?
Old 09-01-2006, 10:38 AM   #1166
Kenneth Tan's Avatar
Hi Ryan/Nexus Racing,
Need help here. The 2 fans on my new cell master v1.0 come on immediately when the charger is plugged onto a power supply. Is it normal? I thought that they are supposed to come on only when the charger heats up to a certain temperature?
Thanks.
Kenneth Tan is offline   Reply With Quote
Old 09-01-2006, 11:23 AM   #1167
Thanks.
Yes, the fans should be off at rest unless the charger is still hot from a previous discharge/charge. Are you in a hot environment or in direct sunlight?
NEXUSRACING.com
Old 09-01-2006, 06:54 PM   #1168
nope. Was using the charger in an air con room at about 24 degree centigrade. Weird thing is that i booted up the charger from cold. It apparently charges ok. Just that the fan noise during idle is driving me nuts at home,and i think the fans will die of overwork.
Old 09-01-2006, 11:48 PM   #1169
You should contact your local distributor to make them aware of your issue. Since your charger is new, you should be eligible for an easy (and hopefully quick) replacement.
NEXUSRACING.com
Old 09-02-2006, 10:14 AM   #1170
Point noted. Thanks!
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 08:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 06:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 03:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 11:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 05:37 AM
