Old 08-10-2006, 07:23 AM   #1126
Nicadrauspro4's Avatar
Hi guys! Maybe you can help.
I've tried charging my AA batts for my TX with the Cellmaster. But the CM doesn't charge it right. I set the CM to 8 cell, 0.9A, 03 Threshold. But my AA batts does not finish the charge and false peaks everytime. My batts are GP-2600 and they are new. I've tried charging them with LRP Pulse Competition 2 and the batts charges well with it. However, my 3800s and 4200s charges with the CM with no problems. I just wonder why it doesn't do the right charging for my AA batts. How do you guys set up your CM for AA charging?
Hoping for some answers. Thanks!
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 08-10-2006, 08:04 AM   #1127
Casper's Avatar
Trader Rating: 34 (100%+)
Your delta peak is way too low. Remember the CM delta peak numbers are for the PACK and per cell as most other chargers are. Turn up the delta peak and this should solve your problem.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 4.0, TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 08-10-2006, 09:24 AM   #1128
Runin Ronin's Avatar
Originally Posted by dasdaman
Just bought one of these chargers, and I am enjoying the features. Just one concern: Is there anyway to reduce the fan noise?? I would be very grateful as it's incredibly loud.
iPod
Runin Ronin is offline   Reply With Quote
Old 08-10-2006, 09:51 AM   #1129
curious mind's Avatar
adjust your delta peak to 15mv, mine works fine...
curious mind is offline   Reply With Quote
Old 08-10-2006, 10:45 AM   #1130
Originally Posted by Runin Ronin
iPod
I'll have to try that! My pit neighbors will also need one.
dasdaman is offline   Reply With Quote
Old 08-10-2006, 11:15 AM   #1131
Nexus Racing's Avatar
What do you set the delta peak to? The weather is HOT where I race.
Using the battery heatsink, I set it to either 06 or 07 in hot weather.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 08-10-2006, 11:19 AM   #1132
Send a message via ICQ to piorc
hey guys, just a question! does the much more cell master charges the new lipo batts?
like orion and peak?
tks a lot
piorc is offline   Reply With Quote
Old 08-10-2006, 11:20 AM   #1133
Perfect, that's where I had it set (06). Thanks again!!!
Old 08-10-2006, 11:29 AM   #1134
AA packs are not matched and have much more resistance in their connections, which causes a lot of voltage fluctuation at the beginning of the charge. The CM has the ability to be super-low on the delta peak settings, so it can false peak if you use a low delta peak setting when the voltage is jumping around. You either have to set a higher delta peak or actvate the long lockout. I charge AA packs like this:
1.5amp linear
07 delta peak
43deg temp cut
If the pack is relatively close to dead, I'll set the long lockout to 15 minutes.
NEXUSRACING.com
Old 08-10-2006, 11:31 AM   #1135
tks a lot
The CM can charge them, but only at a maximum of 1A. Orion recommends a maximum of 4.8A for the Platinum and 3.2A for the new Race-spec carbon edition.
NEXUSRACING.com
Old 08-10-2006, 11:34 AM   #1136
nice...would u sugest agreat charger for both! lipo and nimh?
tks
Old 08-10-2006, 11:39 AM   #1137
tks
Much More CTX Cell Master!!!
I bought my chargers from Nexus Racing
http://nexusracing.net/index.php?cPath=21
Old 08-10-2006, 11:42 AM   #1138
syndr0me's Avatar
Trader Rating: 32 (100%+)
Not for LiPo. My CTX is getting sold since it's worthless for LiPo. You probably want the Ice if you need a decent charger to do NiMH and LiPo. It's not quite as nice as the CTX, but it's cheaper, does a lot of great things, including LiPo. The failure to include this feature in the CTX (above 1A) seems brain-dead from a company as cutting-edge as MuchMore.
For the record, it will charge your LiPo packs, but it will take about 18 years to complete a charge at 1 amp.
syndr0me is offline   Reply With Quote
Old 08-10-2006, 11:47 AM   #1139
1.5amp linear
07 delta peak
43deg temp cut
Thanks Nexus!
Thanks Bing!
I'll try your advice guys. I hope it works with my batteries.
Old 08-17-2006, 04:37 PM   #1140
DR VOODOO's Avatar
R/C Tech Charter Subscriber
HI AFTER YOU DO A CHARGE HOW DO YOU RE PEAK? THE TEMP SHUTS IT DOWN?
OR DO YOU SWITCH TO CHARGE 2
DR VOODOO is offline   Reply With Quote
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 08:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 06:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 03:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 11:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 05:37 AM
