Team Much-More cell master v1 >
Old 05-23-2006, 08:53 AM
  #1081
Originally Posted by Hyper1
So very true! I wish people would learn this..
im learning....!
ickvanovs is offline
Old 06-05-2006, 03:11 AM
  #1082
VooDooPH's Avatar
Trader Rating: 18 (100%+)
hello! newbie on board!
any suggestions on how to use the zero-v and the CM v1 together? i'm using them on kinda old GP3300 hand-me-downs.
VooDooPH is offline
Old 06-05-2006, 07:10 AM
  #1083
Fervidsea's Avatar
Default Organizing
Anyone make any cool cases or disasemble thier CM to combine 2 units into one? I am thinking of combining 2 CM's, a MM, 2 CTXDs with power supply and power strip to a single compact case easier for pit space. Any ideas thoughts or pics. Thanks
Fervidsea is offline
Old 06-05-2006, 07:16 AM
  #1084
Just place the battery on the discharge tray before you charge them.
Tony Vega is offline
Old 06-05-2006, 03:52 PM
  #1085
VooDooPH's Avatar
how long? till the lights dim out? the manual says 3 days... but i'm not sure if thats a good thing to do to nimh batts...
VooDooPH is offline
Old 06-05-2006, 04:09 PM
  #1086
sukh's Avatar
it doesn't take 3 days for the lights to dim, about 30 min on a full charge, its saying to leave your batteries on the trays for 3 days and put them back in about 1 hr again before you race, this is to increase voltage on gp batteries.
sukh is offline
Old 06-12-2006, 05:36 PM
  #1087
VooDooPH's Avatar
anybody know where i can order the cooling fan for the CM? i busted one of mine... :|
VooDooPH is offline
Old 06-12-2006, 06:06 PM
  #1088
Casper's Avatar
Trader Rating: 34 (100%+)
http://nexusracing.net/
These guys sell it all.
Casper is offline
Old 07-06-2006, 06:47 PM
  #1089
I need help with my Cell Master. Today, I was using step charge to charge my GP3700 pack. It was running normally and all the sudden, it says "Input Volt Low Check Supply" So I thought it was my Power Supply problem, so I checked the voltage of it and it's above 13V. I connected the charger again and it still give my the same message. I switched to another power supply (Power Master World Edition 2) and it still give me the same message. The voltage of the PS is in the correct range.
Is there some problem with the charger? (FET blown?)
trf_racer is offline
Old 07-07-2006, 04:08 AM
  #1090
Nicadrauspro4's Avatar
Try setting the voltage adjustment of your powermaster to full. But if it does not work, then have your Cellmaster checked or return it to where you bought it from so they'll replace it with a new one.
Nicadrauspro4 is offline
Old 07-07-2006, 06:44 AM
  #1091
I tried setting the voltage on the Power Master to max, but it doesn't seem to work.
Old 07-07-2006, 11:58 AM
  #1092
Nexus Racing's Avatar
If you can get to the menu settings, try performing the "factory reset".
Otherwise, check the connections on your input wires with the alligator clips. Also try connecting it to the 12V battery in your car.
If you are still having problems, send an email to [email protected] if you are located in North America.
BTW, with a Power Master 2 set to full voltage, the CM may not perform correctly (it may give a voltage error).
Nexus Racing is offline
Old 07-10-2006, 05:13 AM
  #1093
Safer SX's Avatar
When charging a 4300 pack on the cell master at 6 amps do I set it at 3mv or 18mv which one either way
Safer SX is offline
Old 07-12-2006, 09:34 AM
  #1094
syndr0me's Avatar
Trader Rating: 32 (100%+)
Hey guys, is there any information on MM's dedicated LiPo charger we heard about? How about an update to the CellMaster that can do LiPo at more than 1A? Orion is poised to release a new LiPo pack that could get much greater acceptance from the touring car crowd, and it would be nice to stick with MM's quality products when making the switch to LiPo.
syndr0me is offline
Old 07-12-2006, 02:37 PM
  #1095
"All of MuchMore's Li-Po batteries equip a High-Low voltage protector circuit. You can charge MR Matched Li-Po batteries with any type of charger."
this is from their web site.
maybe they will come up with Li-po that you can charge with any charger so no need for any upgrade.????
http://teammuchmore.com/product_info...roducts_id=365
onroaddude is offline
