Old 05-02-2006, 07:28 AM   #1036
R/C Tech Charter Subscriber
Default Fans
Hi Andy,
The fans that come with Cell Master are specially designed only for the charger and operate at 12,000rpm at 12V!
The noise is normal but the high power fans keep the unit cool and enabled it to be a relatively small charger.
Thanks,
Keith.
keithander is offline   Reply With Quote
Old 05-02-2006, 07:36 AM   #1037
excellent thanks once again hopefully that will solve all my problems as I much prefer it over any of the other chargers i've used and want to get a second but need to resolve the issues I was having first.
speedfreakUK is offline   Reply With Quote
Old 05-02-2006, 09:56 AM   #1038
Shop Owner
nnick's Avatar
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
You are using way low delta peak settings for this charger You should use something at the 20-30 range depending on the batteries and ambient temperature.
Nick
Originally Posted by speedfreakUK
Can anyone help ?? Having problems with my MMCM it seems to be very very sensitve and always false peaks, I end up having to put the cells back on my Pulsar to get them charged.
I have checked and double checked the settings. Ive set the delta peak to 4 mv when i usually use 3mv, Temp set to 50 deg and on packs that i have fully discharged and equalised i'm using the lock out for 3 mins to get over the initial false peak problem.
Any ideas ?? As i'm now getting to the stage that i'm gonna have to get rid of it as I can't trust that i'll put the cells on charge before a race and they won't false peak.
Never had this problem with a charger before ??
Many thanks
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 05-03-2006, 12:53 AM   #1039
hi-tech-redneck's Avatar
just to update,tested (factory reset option)given to me from nexus to fix a problem with check clips error message,working good now! nexus rocks!
tularecountyrc.com/the chicken ranch/exeter hobbies/nor-cal hobbies,ripon raceway/hara tcx/losi 22/top photon vta/tekin/reedy/hpi racing/3racing/AT&T/much more/upgrade rc
hi-tech-redneck is offline   Reply With Quote
Old 05-03-2006, 06:09 AM   #1040
Nicadrauspro4's Avatar
How do I set the Cellmaster on charging GP2600 AA batts for my transmitter? What settings should I make? Can I also charge all 8 AA cells at the same time?
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 05-03-2006, 01:27 PM   #1041
junbantay's Avatar
hehe... same Set-up as regular Batts for the Cars but Lower Amps... Choose from .5 to 1.0amp... Ask Justin... he will agree... LOL
junbantay is offline   Reply With Quote
Old 05-04-2006, 11:16 AM   #1042
Thanks Jun!!!
Old 05-04-2006, 02:54 PM   #1043
Qwiglee's Avatar
I need a step charging profile for IB3800s for racing 19t and mod. Anyone help me out?
Brian Aldridge
Qwiglee is offline   Reply With Quote
Old 05-04-2006, 03:01 PM   #1044
acsubie's Avatar
this is what i have been using...
Nexus Racing
acsubie is offline   Reply With Quote
Old 05-04-2006, 04:59 PM   #1045
Mr-s413bt's Avatar
Hey guys
well i just got my 2 cell masters yesterday
can someone help me out with mv settings. On my T35 i use .03 what should i be using on the MM?? i am using the linear mode if that makes any difference. I have heard of ppl using as high 18 on this charger is that correct??
Also what settings should i use for 8aa cells??
Glenn
Mr-s413bt is offline   Reply With Quote
Old 05-04-2006, 05:15 PM   #1046
Korey Harbke's Avatar
What type of battery cells are you using?
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 05-04-2006, 05:20 PM   #1047
Mr-s413bt's Avatar
Hey
Sorry i completely forgot to list them!
IB3800's mainly and the occasional GP3700 AA's are GP aswell
I tried a setting of 3 last night but the cells peaked very cool, just wondering should i up it a bit?
The aa setup would be great, cos i got flat transmitter batteries!
Hope that helps
Glenn
Old 05-04-2006, 08:17 PM   #1048
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
step charging recommended settings always use a very high Amp (7A) for charging. but since that we know that higher Amp reduces the battery life, how come all are still using this profile?
Guys, so basically which do u choose to charge ur battery? Peak or step charge? coz everytime when i use peak charge for my 3600 or 3800 pack, it will always end with peak cut at around 3100, does this mean that the pack is not fully charged? also as from the nexus racing profile, i noticed that the MAH setting for step charge is way more than 10% of the battery capacity, so is it good? as for step charge, i have lowered from 6A to 3A (1/3), is this ok?
i know MMCM is a great charger, but its just that i think its too complicated to use, esp for a newbie like me. can someone help me out on charging profile for my battery BOTH ON peak & step charge?
- Tamiya 3600
- Intellect 3800
- Energizer 2500 AA Tx battery x 8pcs
uniquexme is offline   Reply With Quote
Old 05-04-2006, 08:51 PM   #1049
uniquexme's Avatar
after reading the nexus site, only then i realise the thermometer probe is to be placed at the cooling fan stand, and not to the battery directly.
Old 05-04-2006, 11:53 PM   #1050
Joep's Avatar
Please explain or please give a link?
I absolutely do NOT understand what you mean.
Xray T3 for dry and Xray T2'009 for rainy weather. Sponsored by: Myself and my wife.
Joep is offline   Reply With Quote
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 08:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 06:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 03:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 11:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 05:37 AM
