Old 06-29-2005, 01:50 PM   #541
Arun's Avatar
Originally Posted by komkit
Not a problem, ours sound alike and starts with "K"
Arun, how do you prepare IB3800 before charging them? Do you tray them down before charging?
I will try the profile that you posted next weekend. Not sure if I will get the packs before this weekend.
Thanks,
Komkit, Michael from ThunderRC did recommend traying them down before charging. He also mentioned that if they are going to be stored for two weeks or more, you should put a 500sec charge back into the pack (after taking it down to .90v per cell first). Some people are also beginning to dead-short for stock/19t much like with 3300's, but this is ONLY with the newest batch of cells. Apparently, there have been like 7 revisions so far.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 06-29-2005, 02:23 PM   #542
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Arun, that'll work. Yeah, he recommended the charging setup for my GFX. But for MMCM he recommend to ask you.
7 rev. of production in a few months not too bad. There is no marking, I guess..
I'll let you know in a week or so how it work Got to give Kumpol a call, I need 1 more MMCM
MMCM made my 17 months old (8 packs) working like they were just bought 2 months ago...
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 07-02-2005, 07:32 PM   #543
Alex C's Avatar
Trader Rating: 50 (100%+)
Originally Posted by kumpol
Step 1
2600mA 7.0A
Fn
Step 2
2630 0.2A
Fn
Step 3 4200mA 5.0A
Tn 48 10 R1
repeak 1 delay 5min. repeak capacity 250mAh
This profile is from Ryan Lee. He set this for a couple people in 19T class at the Reedy 2005. And I found out this was very good for 19T class at the Reedy.
Question?
On step 3 4200mA 5.0A
Tn 48 10 R1
What does (Tn 48) mean
What does (10) mean
and was these CTX charge profiles for a battery than has been taken down to 0.0 Volts!!
Thank You all in Advance for all the Information!
Best Regards
Alex
Alex Cortez
Thank You to all My Sponsors
Ko Propo USA / RC America - Xray - Hudy / Max Power Engines / VP PowerMaster Fuel / Team Espo - "Lay it down Prop"!!!!
Alex C is offline   Reply With Quote
Old 07-02-2005, 08:00 PM   #544
s2
s2's Avatar
Originally Posted by Alex C
Question?
Tn 48 10 R1
What does (10) mean
Best Regards
Alex
Hi,
Tn, means that 'Trickle - No', during CTX setup the trickle feature must be on the 'No' state, basically trickle turned off
48, this is the temperature at which the cells will stop charging if they get to 48*C before the peak detect activates.
10, this is the Mv value of the peak detect for the whole pack, 10Mv.
CTX charge is only for discharged cells, if u try to CTX charge a partially charged pack due to the 1st to CTX stages having long lock out activated theses partially charged cells may become overcharged, i do not think 0.0V is nesesserally needed the regular 5.4V discharge is fine. I think for best results it is best to tray cells to around 5.4V, then put straight to charge.
Regards,
Stew
s2 is offline   Reply With Quote
Old 07-02-2005, 08:09 PM   #545
Alex C's Avatar
Originally Posted by s2
Hi,
10, this is the Mv value of the peak detect, 10Mv.
Regards,
Stew
Thanks Again Stew for all your help
Alex Cortez
Old 07-02-2005, 10:27 PM   #546
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Guo Chen,
Here is one profile for 3700/3800. The newer cells seem to be more sensitive to overcharge, so I would not set the delta peak any higher than 06 or the temp any higher than 48. It is important that the 3700 and 3800 batteries peak below 130 deg Fahrenheit.
Step 1
3050mA 7.0A
Flex off
Step 2
3080 0.2A
Flex off
Step 3
4900mA 4.0A
Flex off
Temp 48
delta peak 05
Hara used a different setting at the Reedy Race with 3700:
Step 1
50mA 0.7A
Flex off
Step 2
2500 7A
Flex off
Step 3
4600mA 5.5A
Flex off
hey Arun
will it have any difference if i set it to be 03 instead of 06? it mean 03=0.003 per cell or for whole pack? thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 07-02-2005, 10:30 PM   #547
Guo Chean's Avatar
for SMC they had recomemded to charge their cell at 6 amp linear and 0.03(30MV) so what should i put on the delta peak in cell master? 03 or 30? thanks
Old 07-02-2005, 10:43 PM   #548
wyd
Tech Legend
wyd's Avatar
Send a message via AIM to wyd
03. You go 30 and your more than likely over charge and melt down you packs.
ST Racing Concepts (STRC)
Old 07-02-2005, 11:31 PM   #549
Guo Chean's Avatar
is that 03 stand for 0.03volt delta peak???
Old 07-02-2005, 11:42 PM   #550
Ryan Lee's Avatar
Default 03 stands for
0.003V =3mV
Ryan
Ryan Lee is offline   Reply With Quote
Old 07-03-2005, 01:50 AM   #551
Guo Chean's Avatar
Originally Posted by Ryan Lee
0.003V =3mV
Ryan
so like SMC recomemded 0.03V for peak detect i need to put it until 30MV? so what actually i need to set the delta peak detection? 03 or 30? thanks
Old 07-03-2005, 05:26 AM   #552
komkit's Avatar
0.003V =3mV
Ryan
Ryan,
Let me see if I understand this right.
MMCM delta peak setting is base on individual cell NOT the whole pack?
Because there is no possible way for the MMCM to monitor and taking the voltage sample for individual cell while we are charging the cells in series.
If 03 in the setting mean 3mV and in the set up menu when you tell the MMCM that you are charging 6 cells pack. Then the MMCM will do the calculation for you and monitoring 18mV NOT the 3mV
If the setting is set for 4 cells, then the MMCM will monitor 12mV.
Do I understand this correctly?
Old 07-03-2005, 05:27 AM   #553
komkit's Avatar
Regardless, you want one......I can see it in your eyes....you keep looking over my shoulder
Old 07-03-2005, 06:09 AM   #554
antoniop's Avatar
http://www.mrc-pt.com/downloads/e5-6.pdf
At the end of last page it says 03-99 MV/pack.
The setting is for the WHOLE pack.
antoniop is offline   Reply With Quote
Old 07-03-2005, 07:10 AM   #555
komkit's Avatar
Thatís why I was just wondering. To me 3mV/pack seems a little bit too low. If I was to charging a 6 cells pack with 3mV threshold setting. Meaning 3mV divided by 6 cells = 0.05mV. Now thatís 50 microvolt per cell. Even we bumped up the threshold to 6mV/pack still that gives us 1000 microvolt. We will all have to have IDENTICAL characteristic cells in our pack. It doesnít take much for a single cell to drop 1 or 2 mV during its peak. Its only takes 2 cells to drop more than the other 4 cells.
The step charging is pretty much guaranty 1 and 2 steps your pack will never fault peak. But what about the 3 step? So your cells in that particular pack have to be a top notch or a perfect matched, otherwise you might be having 2 bad apples out of 6 apples. That is if the threshold is setting TOO LOW.
Individual cell charging and monitoring system is the way to go I guess. MMCM is the way to go as of right now, Iíll experimenting some more on the threshold settings. In my opinion Iíd rather cooked my packs then not having enough juice.
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 08:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 06:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 03:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 11:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 05:37 AM
