Old 06-13-2005, 03:09 PM   #496
Regional Moderator
kumpol's Avatar
Originally Posted by JasonC
by any chance does any one have the deminsions of this charger
Dimensions....124x114x47mm
Weight............482g
kumpol is offline   Reply With Quote
Old 06-13-2005, 04:04 PM   #497
Arun's Avatar
Originally Posted by RBLove
If that is the case why are all of the charging methods on the CM using a 3 to 6 delta v? Seems extremely low... I guess I will try 6 amps with 30mv on my CM's and see what I get??????
I received this great information from Ryan Lee a little while ago. It explains why we use lower delta peak settings on the Cell Master compared to other chargers:
Originally Posted by Ryan Lee
Cell Master is super linear charger which means very pure current.
If charging current is not stable,
the voltage goes up and down during charge,
it may cause "False peak" if you set low delta peak with other charger.
But, as u can see, with 3mV setting (0.5mV per cell), CM does not make False peak.
And we always recommend 3~6mV on CM's instruction. because lower delta peak value make loger life for your batteries.
We don't want to hurt our customer's battery.
But for race, the story goes different.
Every serious driver want punch.
Warm battery(43~48degree C) after charging make punch as u know.
So we increase delta peak value.(10~24mV)
Compare to other chargers, the value still seems low.
If you want to compare two kinds or chargers,
you need exact Amp(current) meter and volt meter.
Many other chargers cheating their charging amp(or their calibration is not exact)
Even if it shows 5A on the display, it may be 4.5A or so.
Cell Master charges at actual amp as it set to.
And Eagle CDC series, Integy charger, Quasar etc. has charging pattern as below.
55sec charging,
5sec stop charging
55sec charging
5sec stop charging...
Above charging way can decrease temperature but can't expect punch.
16bit AD and super linear current can make 3mV deltapeak cut off.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 06-15-2005, 02:24 AM   #498
Default ib3600,s only going to 2900mah
Just wondering if any one can tell me why my 3600s only charge up to around
2900mah. they have only been used 8-10 times each and are always discharged to 5.4 arfter every run. ive tried peek charging and step charging as per manual.they seem to always cut out around 2900mah-9.3volts.
Regards:Andrew.
Andrew j is offline   Reply With Quote
Old 06-15-2005, 03:05 AM   #499
Ryan Lee's Avatar
Default 3600 cell
Regards:Andrew.
After charge, check the temperature of cell.
If they are not enough warm, charge them again with Peak charge mode.
After charge, temperature should be around 42~50degree.
Higher deltapeak value also will help.
Please try 10mV ~ 16mV.
And make sure keeping good contact between alligator clips and your battery.
This s very important.
Thank you,
Ryan Lee is offline   Reply With Quote
Old 06-15-2005, 06:31 AM   #500
1fastdude's Avatar
Trader Rating: 15 (100%+)
Andrew j Do you discharge the cells individually down to zero before charging. If not that could be the reason for low mah numbers!
★RCAmerica •Xray •Hudy •BSR/Jaco •Absolute Hobbyz •Gravity RC •PROTOform •Avid •TQ Racing Wire •C & M Motorsports ★
1fastdude is offline   Reply With Quote
Old 06-15-2005, 05:09 PM   #501
What is the difference between this charger and the Orion advantage? Are they one and the same? I would like to get this charger but the Orion is more accessible to me.
nolan_racing is offline   Reply With Quote
Old 06-15-2005, 05:51 PM   #502
TeamMuchMore's Avatar
MuchMore Cell Master and Orion Charger is COMPLETELY DIFFRENT product. They are made by diffrent manufacturer.
TeamMuchMore is offline   Reply With Quote
Old 06-15-2005, 06:04 PM   #503
Thanks for the clarification.
Old 06-16-2005, 06:08 PM   #504
FaiLip's Avatar
Any idea where I can get myself one of this and other great Team Much More Product in New Zealand, or country close by?
FaiLip is offline   Reply With Quote
Old 06-16-2005, 06:33 PM   #505
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
www.hobbyx.com in Sydney, Australia is the official distributor of much more products. Might be worth giving them a ring.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 06-17-2005, 04:34 AM   #506
Thumbs up
I just received my today! Have read instruction manual and charged one 3700pack. All what I can say about it- that’s the best thing what you can buy for that price! Very impressive!
JanisK is offline   Reply With Quote
Old 06-21-2005, 09:34 PM   #507
centax error!'s Avatar
Default Questions on the CTX mode
Finally got a Cell Master
I am discharging my batts to 0 Volts using the DS feature of the Novak Smart tray and used solder across the terminals and store them deadshorted for days.
My question: Is it safe to connect the charging terminals on the batts while the solder is still on and leave it until a minute of charging using the cell master ? the reason I want to do this is that I dont want the cells to recover voltage right away becasue as soon as you remove the solder the volts will increase.Let me know your thoughts?
CE!
centax error! is offline   Reply With Quote
Old 06-21-2005, 09:37 PM   #508
danjoy25's Avatar
I should be ok as long as you don't start charging as you will get an error message.
Old 06-21-2005, 09:44 PM   #509
VenomWorldOrder's Avatar
the mind games have begun danjoy YOUR GOING DOWN SUCKA!
VenomWorldOrder is offline   Reply With Quote
Old 06-21-2005, 09:52 PM   #510
Danjoy, I will start charging and plan to leave the solder there for about a minute or so so the cells won't recover.
I have done this on the GFX and remove the solder after 3 seconds of charging but on my T35 Stealth I will get an " AMP set too low " error message. And want to know if anyone have tried this method on their Cell Master.
Thanks.
CE!
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 08:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 06:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 03:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 11:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 05:37 AM
