Old 06-12-2005, 07:58 AM   #481
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
If you step charge, do you have to discharge your pack to o.o volts or can you take them down to 5.4 (6 cells using the charger) before you step charge?
DirtyDog3375 is offline   Reply With Quote
Old 06-12-2005, 08:16 AM   #482
Ryan Lee's Avatar
Default Fan control after charge
Originally Posted by Joep
Why is the fan not controlled by temperature after charging?
Cells tend to increase their temp. after delta peak cut off.
Or am I missing a setting?
Hi, you are missing some important setup.
Maybe CM's algorithm is too hard for everyone?
Push < button and hold for 3seconds on main menu.
-User setup mode
-Output Control Pins
-You can choose Fan or Warmer
-choose "Fan"
-"On" in rest
-Set target temperature
Your fan will blow when it gets to target temperature after(or before) charging.
Ryan Lee is offline   Reply With Quote
Old 06-12-2005, 09:43 PM   #483
Ryan Lee's Avatar
Default Li-Po charge
Originally Posted by kumpol
Make sure that you can charge the Li-Ion&Polimer upto 11.1V (3cell) with the Cell Master.
I have not used my Cell Master to charge any LiPo cells yet. I will try and let you know later.
For charging Li-po or Li-Ion,
Li-po or Ion should be charged in different way for safety.
When the voltage reaches to certain point(it depends on cell no.), charging way chages from linear current to linear voltage. That's why charging cuurrent goes down.
When the charging current goes down to 0.1A, charge terminated.
Thanks,
Ryan
Old 06-12-2005, 10:01 PM   #484
Korey Harbke's Avatar
I just picked up a Cell Master from Rain City Raceway, and I must say I'm extremely impressd with the quality and performance of this little charger. It's awesome!!!! The step charging feature is super cool. My batteries are already starting to come alive compared to my other charger.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 06-13-2005, 12:00 AM   #485
RBLove's Avatar
Trader Rating: 72 (100%+)
06 on the CellMaster = 6mV(0.006V)/pack
It looks like a high number per pack but you will not get overcharged 'coz the peak cuts at 48 degree C (118 Fahrenheit).
Last clarification. If someone is charging on a GFX @ 6amp with a .03 cut off; What is the same setting on a Much More Cell Master? 6amps with a ???
Thanks Kumpol......
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 06-13-2005, 12:16 AM   #486
Regional Moderator
kumpol's Avatar
Thanks,
Ryan
Great info....thanks to Ryan!
kumpol is offline   Reply With Quote
Old 06-13-2005, 12:22 AM   #487
Regional Moderator
kumpol's Avatar
Thanks Kumpol......
edited.....look for answer from Ryan...
Old 06-13-2005, 12:25 AM   #488
Joep's Avatar
-User setup mode
-choose "Fan"
-"On" in rest
Thanks man.
I completely overlooked that.
Xray T3 for dry and Xray T2'009 for rainy weather. Sponsored by: Myself and my wife.
Joep is offline   Reply With Quote
Old 06-13-2005, 12:47 AM   #489
Ryan Lee's Avatar
Default Delta peak CM VS Turbo
Thanks Kumpol......
I remember Turbo's delta peak like this,
Turbo's .01 is 10mV = CM's 10mV
Turbo's .02 is 20mV = CM's 20mV
Turbo's .03 is 30mV = CM's 30mV
If voltage is less than 2V(1cell), Turbo will cut off charging by 2mV.
Turbo is very accurate charger for 1cell.
Ryan
Old 06-13-2005, 02:44 AM   #490
Originally Posted by Hebiki
i agree with hector there... my practice packs are getting longer run times while also retaining its punch (although the batteries are dying since i use them constantly).
it also helps to have the Team Much More Zero trays for each pack.
hi ryan! keith! jk! whats up guys.
I thought you weren't meant to zero rack ib3600's? I am sooooo confused.
Also, with step charging these cells(ib3600), do you have to take them down to o.o volts first or can you start charging them from 5.4 volts? Please help??? anyone???
Old 06-13-2005, 04:07 AM   #491
Joep's Avatar
Default Fan Plug & Fan max. Output
Got 2 questions:
1) Where can I get the type of plug used for the fan?
2) How many Amps can the fan-output deliver?
Thanks in advance.
Old 06-13-2005, 09:52 AM   #492
RBLove's Avatar
Ryan
If that is the case why are all of the charging methods on the CM using a 3 to 6 delta v? Seems extremely low... I guess I will try 6 amps with 30mv on my CM's and see what I get??????
Old 06-13-2005, 10:57 AM   #493
litespeed-dom's Avatar
Got 2 questions:
Thanks in advance.
Believe it or not, I spent 1 full week going to different shops looking for the fan/warming tray plug, couldn't find anything at electronics, computer type store. And more unbelievable is one day I stumbled across a surplus electronic type place, they guy pulled a battery out of an old old cordless phone and the plug seems similar, I had to maybe do a mod to make it fit. Then I went home, thinking I too have a cordless phone I don't use, I open the battery door, pull the plug and I can't believe what I was seeing....it's the IDENTICAL plug on the MR CM!!! I even unsoldered the male plug from the phone's circuit board.
So check your cordless phone!
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 06-13-2005, 10:58 AM   #494
I too didn't understand if the mV is for per pack, why are guys putting out their setup talking about each cell???
Dom
Old 06-13-2005, 01:25 PM   #495
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
by any chance does any one have the deminsions of this charger
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 08:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 06:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 03:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 11:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 05:37 AM
