Team Much-More cell master v1
#391
hey will you guy facing this problem. i just get my package of power master to day but when i open the box and try it to charge my battery. unfortunately i wont run anything even led also no light. it totally did not run so what should i do for the power supply? then frustrated buy a new thing and cannot used after waiting for so many day for shipping.
#392
Regional Moderator
#394
some power supplys had to switch from 220v to 110v
Instructions for alternating between 220V and 110V input.
"The following is for information only and should only be carried out by a qualified electrician and is NOT approved by the manufacturer or distributor
1. Unplug unit from mains supply and leave for at least 2 hours. Remove 4 screws from outer cover. Locate grey jumper lead fixed to 220V pin.
2. Take care not to touch any other components. Remove grey jumper lead from 220V pin.
3. Re-locate grey jumper lead to 110V pin."
4. Replace four screws and secure outer case.
#395
Power Supply sold under US branch of MuchMore is already Adjusted to 110V.
Only Version of MuchMore power supply we sold is world edition. if it is regular MM powersupply it didn't came from us.
I personally did the Quality Control for each unit of power supply sold by our branch. every single one of them were turned on and provided right voltage.
thanks
James Kim
#400
Originally posted by AlanLim
I found this Hara's profile:
Step Charging
Step 1
0-2500 mAh 7 amps, linear.
Step 2
2500-2550 mAh 0.2 amps, linear.
Step 3
2550-4200 mAh 6 amps
Peak 3mV per cell, Temp 50°C, Max mAh 4200.
Temp at 50°C? so I think step charging provides cooler charging process then.
Step Charging
Step 1
Step 2
Step 3
For the delta peak, it says 3mV per cell so I have to set it at 8mV for a 6 cells pack? Doesn't Much More recommand 3mV for the whole pack?
#401
Does step charging work with stick packs? Specifically six cell spec packs.
#402
#403
Hey does anyone know where can i get the whole instruction manual for team much more power master because i need to switch the input power from 110 volt to 240 volt when i bring it to back to my country so i do not want just because i not familiar with this power supply and causing it damage. and second question may i know for the glass tude fuse in 250 volt and 5 amp where to get in United States or i just using 110 volt ad 5 amps fuse? thanks
#404
Originally posted by Arun
There is no reason why it wouldn't. Depending on the type capacity of the spec cells, you'll have to adjust your profile. You have to be sure the pack will peak in step 3. If it does not, the battery will overcharge in step 1 or 2, and hurt the battery. If it is a NiCd, you could also take advantage of the flex charge feature.
#405
All spec packs are NiCd 1600MaH,how would you set up a step charge profile for these?
I would probably start with something like this:
Step 1
1150 7amp
flex on
Step 2
1200 .3amp
flex on
Step 3
2400 4amp
flex on
delta peak cutoff .06
temp cutoff 52 (125 deg Fahrenheit)
I would recommend to use the flex feature in all stages. My experience -though limited- with NiCds has shown that they like to be flex charged. There used to be many that would flex thier 1500 packs in a spec class at my old track.
