Old 03-01-2005, 01:09 PM   #256
TeamMuchMore's Avatar
Default MuchMore Power Supply
That power supply is "World Edition"
it's got fuse circuit and switch.
TeamMuchMore is offline   Reply With Quote
Old 03-01-2005, 05:16 PM   #257
Company Representative
Trader Rating: 15 (100%+)
Has anyone tried the "Hara" profile?
feedback?
thanks
Korgae
WCICS- Competition Director
Korgae is offline   Reply With Quote
Old 03-01-2005, 05:36 PM   #258
Default Re: RE:CM
Originally posted by Ryan Lee
Thanks for your reply Ryan.. just another question,
if i'm charging my NiCD batteries, how do i determine what "flex charge" setting should i use?
it seems 9 is best for the battery? or am i wrong?
will there be any performance difference between setting 1 and 9?
yellow15 is offline   Reply With Quote
Old 03-02-2005, 12:28 AM   #259
Ryan Lee's Avatar
Default Re: Re: CTX
Originally posted by Windtalkers
Ryan,
is this the one?
Yes. it is.
That is proto type, product will be better looking.
Ryan Lee is offline   Reply With Quote
Old 03-02-2005, 12:31 AM   #260
Ryan Lee's Avatar
Default check the terminal
Nick,
Please check output terminals if they have bad connection.
If the conection between terminal and nut, it may cause heat and blow.
Please check then let me know the result.
Originally posted by nnick
Hello,
I have bought 2 CTX Power masters.
When my friend used his for the first time everything was ok. Second time he used it with only one charger on (Futaba CDR-5000) the fuse blown up after of almost 10min charging time.
When he checked the power supply he found out the the 2 output circuits were fried (7QA 7N80 is what their label on them).
When he changed them with new one and he plugged in the charger (without charging) it was ok. He left the power supply on without any charger it was ok. When on another day, he hooked up another charger the fuse blow up again!
Any ideas what will be the problem and any solution to solve this ?
Thank you
Nick
Old 03-02-2005, 12:35 AM   #261
Ryan Lee's Avatar
Default Bug
Originally posted by Kenneth Tan
Hi Ryan,
Any idea why my CTX Repeak capacity limit always change value when i restart the charger?
That is kind of program bug,
Please set capacity limit 250mAh which will not be changed and also work well as repeak charging capacity.
Old 03-02-2005, 12:40 AM   #262
Ryan Lee's Avatar
Default Re: Re: CTX
Originally posted by Fatboy Joe
Hi Ryan,
I recently bought 2 cell masters and i always get this error: "CHECK CLIP", i consulted keith of much more u.k., he told me that the leads of my batts (which are battery bars) cant take the amps when the alligator clips are connected during charging. can i just hard wire the charger leads to my batts during charging like some pros do or there's a solution for this? thanks in advance
sonny
When you have that kinda trouble, please cehck the voltage of battery on the display LCD. If it shows 13.XXX(suppy volt), it is bad connecion as Keith cosulted you.
If you have any consious on your battery's connection, re-solder all battery bars. then try charge again.
Thanks,
Old 03-02-2005, 12:53 AM   #263
EddieO's Avatar
R/C Tech Charter Subscriber
Slightly off topic, but I have a motor master v3.0c....at snowbirds, the display just freaked out....the unit still works, if you can figure out what setting it is on by look at an angle, but all the display just shows blocks in different shades (hence why you can kinda read it, if you look at it angle)...
Any idea what this is or do I just need to send it in for repair......
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 03-02-2005, 01:01 AM   #264
J-P
J-P's Avatar
where can i get a worlds power supply??
thanks
J-P
J-P is offline   Reply With Quote
Old 03-02-2005, 01:08 AM   #265
Ryan Lee's Avatar
Default Re: Re: RE:CM
Please regard Long lock out as insurance against False peak.
At the beginning of charge(approxi. from start to 20min.), voltage may drop or be unstable.
Long lock out will not make any false peak.
Here is another tip for LLO
If you set LLO 20min,
you apply LLO after 3min.of charging,
LLO will act 17min. from now.
Do not apply LLO for charged battery.
Temp cut off funtion has priority than peak cut, capacity cut, long lock out etc.
Temp cutoff >Delta peak cut>Capacity cut
Thanks,
Ryan
Originally posted by Cole Trickle
Okay, so the "Long lock out" is global? It's not any good for manual re-peak
Will the temperature cut off always work, regardless of other settings? ( of course, the temp probe should be mounted )
Old 03-02-2005, 01:13 AM   #266
Ryan Lee's Avatar
Default Freaked out LCD
Sorry to hear that,
I think LCD demaged(or bad connection), need replacement of LCD.
Please ask LHS where you bought to.
We guarantee Motor master 120 days from the purchase.
If you have receipt to prove purchase date, pls send them all to LHS.
Thanks,
Ryan
Later EddieO
Old 03-02-2005, 01:20 AM   #267
Ryan Lee's Avatar
Default Flex
Even us have not been tested much of Flex for old NiCD batteries.
But I found Flex 9 worked well for old Sanyo 3000 or NiCD.
I set F9 until 500mAh for old batteries.
9 has the highest intensity.
Please try several settings for old NiCD.
It is not so easy to have "old NiCD samples" .. as hard as very new one!
Thanks,
feedback?
thanks
Korgae
Old 03-02-2005, 05:06 AM   #268
Cole Trickle's Avatar
Default Re: Re: Re: RE:CM
Thanks,
Ryan
Thanks. I dont have the Cell Master (if I can sell my current charger ... ), but I found in the manual, that the LLO is optional, when you start the charging
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 03-02-2005, 05:12 AM   #269
Trader Rating: 74 (100%+)
Default llo function
Ryan,
I dead short my GP3300's, and currently using the CTX mode. but if I charge with the standard peak function, they false peak over and over. I have the llo option on 20 minutes. But the problem is this, you say the window of 3 minutes it is not engaged, this is when you need it the most. Is there a way to start the lockout when you hit start for charging?
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 03-02-2005, 05:35 AM   #270
I believe you have to hit the start button for at least 2 seconds... But I dont have the charger myself, so I'm not sure, I've just read the manual...
Some clarification about this, will be really appreciated
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 08:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 06:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 03:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 11:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 05:37 AM
