Old 08-17-2007, 07:20 PM   #1606
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
Originally Posted by SkeeryJones View Post
becasue the MM is a real sensitive charger. a good thing.
normally on any other charger you would have 3mv/cell thats 3mv x 8cells for the muchmore = 24mv.
so change your peak settings to 24-30mv and try charge again.
thanks.. i will try later..
hello miss, puwede pa bind?
nikkiesteban is offline   Reply With Quote
Old 09-27-2007, 07:42 AM   #1607
turboxrayt1fk05's Avatar
Trader Rating: 27 (100%+)
best mv/ per amps setup for charging 6cell packs at 6amps , 7 and 8 anybody could help me on this.....
SERPENT S811 AND S811T, FUTABA 4PKS , viper rc solutions
OS SPEED WORLDS EDITION 21 , OS 2060 PIPE
BYRON %30 FUEL , PROTEK 2300 LIPO RX PACK
SAVOX SERVOS 1268MG HV , 1267MG HV
turboxrayt1fk05 is offline   Reply With Quote
Old 09-27-2007, 02:15 PM   #1608
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
Use from 21-30 depending on ambient temp, w/ a 51 degree temp cut. You can use the same mv for 6,7, and 8 amp charge.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 09-27-2007, 03:53 PM   #1609
ok the question still stand sense i'm getting different info from everybody , i got this email from Arun @ nexus racing : quote:
It is not per amp, it depends on how many cells you are using and how aggressive you charge. Delta peak is the amount the voltage drops before the charger considers the battery peaked.
0.006V is a more aggressive setting than 0.003V because it is bigger. If you charge at 10 amps, you might want use a lower delta peak to prevent cell damage. In other words: as you increase the charging rate (amps), you sometimes decrease the delta peak, but you never increase it.
0.006 for the pack is equal to 1mV/0.001V per cell…so to be consistent you would use a 0.007 for a 7-cell pack and 0.005 for a 5-cell pack on the Cell Master.
At 7 amps, I would use the same delta peak. At 8+ amps, I might lower it to 05 or so unless I’m charging in a cool area. If the cells do not get up to temperature in a cooler area, I would increase the delta peak little-by-little until they reach 120degrees right at the end of charge.
-Arun
Nexus Racing
Old 09-27-2007, 04:02 PM   #1610
magm20001's Avatar
nexus is right, CTX-C the delta figure is the TOTAL voltage drop off.
nearly every other charger, the delta peak refers to a per/cell figure.
thats why on the ice a 0.3mv/cell for a 6 cell would be 18mv on the muchmore ctx-c.
so the muchmore can delta peak in much finer increments (higher resolution)
magm20001 is offline   Reply With Quote
Old 09-27-2007, 04:06 PM   #1611
i got this example from nexusracing website:quote:
While you may use a 0.03V (30mV) delta peak setting on a CE Turbo 35, you will use somewhere around a 0.006V (6mV) setting on the Cell Master.
Data Conversion Table:
delta peak: decimal: fraction: input setting on cell master:
30mv 0.030v 30/1000 30 delta peak
3mv 0.003v 3/1000 03 delta peak
of a volt
Old 09-28-2007, 06:29 AM   #1612
ok , delta peak ? still stand , which is the correct setting , i'm getting between 21-30 and also between 05-06 ,,,,,,,,,,,,,, this is just any pros out there with good ,,,,, i'm not saying previous post are not correct but i'm getting different answers.
Old 09-28-2007, 09:01 AM   #1613
johntrickle1's Avatar
Default power supply
Hello all,
I have a question about power supplies for my cell master. Just purchased a Radio Shack 23 amp power supply that works Great with my Tekin and Novak chargers, however when I hook up my Cell Master to it I get an error message. If I hook it up to my 10 amp power supply my Cell Master works great.
My Cell Master is All Black and does not have the magnetic temp probe. Do any of the newer versions have this Problem? And can this be fixed easily or do I have to send it in for a software or component upgrade?
thanks.
johntrickle1 is offline   Reply With Quote
Old 09-28-2007, 09:06 AM   #1614
Casper's Avatar
Trader Rating: 34 (100%+)
It should work great with that P/S. Is there a switch on the P/S to convert between 12V and 14V? What is the error message?
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 4.0, TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 09-29-2007, 03:02 PM   #1615
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
how's this charger for lipo?
sounds like the bee's knees for nimh but id be using both. thanks
also, is there any differences between andy, marc, and std editions other than the sweet cases?
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 09-29-2007, 04:08 PM   #1616
magm20001's Avatar
does lipos only at 1amp. (max)
only cosmetic difference between all of them (case and screen)
Old 09-29-2007, 04:24 PM   #1617
rdub202's Avatar
ouch, bummed now, i was really lookin at getting one of these
Old 09-30-2007, 08:52 AM   #1618
wallyedmonds's Avatar
the new MM charger dose lipos
its called the cellmaster platinum
and theres a new discharger the dos 5 cells
and a new motor master but i dont know what it dose different.
wallyedmonds is offline   Reply With Quote
Old 09-30-2007, 09:02 AM   #1619
the way i understand it on the muchmore you set the cut off at 3mv a cell witch is .12 on the screen
on the gfx you can only set it to .01 witch is like 10 on the muchmore
this is for 4 cell.
for 6 cell its 22 and on the gfx .02 witch is like 20 on the muchmore.
so you can say that the gfx dos not charge the cells fully but really will you notice this NO
Old 09-30-2007, 10:09 AM   #1620
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
fwik "Platinum Edition" only refers to the reverse-colored screen (black/white display). Otherwise, all the features are the same as the standard unit.
i could be wrong tho...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
FS/FT: TEAM MUCH MORE Motor Master & Cell Master litespeed-dom R/C Items: For Sale/Trade 15 06-15-2006 08:44 PM
Team Orion Advantage w/ LiPo or Team Much More Cell master? RH Customs Electric On-Road 6 04-06-2006 06:05 PM
Team Much More Cell Master FRP R/C Items: For Sale/Trade 4 01-25-2006 03:04 PM
Team Much More Racing CTX Cell Master and CTX Motor Master letitroll R/C Items: For Sale/Trade 7 11-18-2005 11:25 AM
Team Orion Advantage or Team Much More Cell Master charger alana07 Electric On-Road 1 12-18-2004 05:37 AM
