Old 01-01-2012, 09:53 PM   #76
Dread Pirate's Avatar
Trader Rating: 15 (100%+)
Originally Posted by EAMotorsports View Post
1) Are the rear ride height adjustments standard (AE/CRC) or unique to X-Ray? Xray specific.
EA
Thank you, does the kit come with all the sizes or do I need to order them?
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
Dread Pirate is offline   Reply With Quote
Old 01-01-2012, 09:55 PM   #77
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Comes with them all I think. My full kit should be here this week to know. But it should be all of them. My past kits had them all.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 01-02-2012, 02:26 AM   #78
Marek Gadomski's Avatar
Originally Posted by aloksatoor View Post
where can you buy it in the states?
rcamerica.com
____________________________________________________
Tamiya TRF 417X-Speed Passion-Thunder Power-KoPropo
[email protected]
http://www.facebook.com/marc.gad
Marek Gadomski is offline   Reply With Quote
Old 01-12-2012, 06:12 AM   #79
Originally Posted by HappyHippo View Post
This in one off my prototype cars that I used in Mod, IIC 2011 Las Vegas
Alf
alf.skaar is offline   Reply With Quote
Old 02-05-2012, 05:02 AM   #80
adri-13's Avatar
Hello all!
Here's a post in my blog talking about my XRAY X12:
http://rcracereportsigm-racing.blogs.../xray-x12.html
PETITrc driver
www.PETITRC.com
http://rcracereportsigm-racing.blogspot.com/
adri-13 is offline   Reply With Quote
Old 02-05-2012, 09:49 AM   #81
Originally Posted by adri-13 View Post
Hello all!
Adri-13,
Thanks for your comments.
Has anyone else had issues with the front bearings having play on Jaco wheels?
Old 02-05-2012, 10:01 AM   #82
Trader Rating: 36 (100%+)
Default Play in Jaco wheels
Dread,
I've noticed that as well. Started double-checking all my linkages and ball ends, narrowed it down to the bearings fitting VERY loose in the front wheels (Lilac). Such a sloppy fit, I'm going back to running Exceeds. Half the cost of Jaco and the bearings fit like they're supposed to
Rcdiver is offline   Reply With Quote
Old 02-06-2012, 08:50 AM   #83
Interesting; odd problem.
I'm planning on getting an X12 when I get time to run again; I assume I can put other bearings on that will fit fine.
Old 02-10-2012, 09:41 AM   #84
adri-13's Avatar
It's just a little play. This problem give a little imprecision in neutral position...
I have not find an alternative for this.
PETITrc driver
www.PETITRC.com
Old 02-10-2012, 09:55 AM   #85
The problem is not with the bearing but the Jaco wheel. The hole for the bearing is too large. There is an easy fix. Take some old sticker/decal material and cut out a circle or square piece of the material a little larger than the hole in the wheel and stick it over the bearing hole. With a sharp knife, cut a "X" in the sticker/decal material that is covering the hole. Then press your bearings into the wheel and all slop will be removed. Jaco was supposed to have fixed this problem in their wheel mold but maybe they have not corrected this problem yet.
Rocket RC Speed Shop - USA Importer of Team Powers products
[email protected]
http://rocketrcspeedshop.webstorepowered.com/
Crashby is offline   Reply With Quote
Old 02-10-2012, 10:22 AM   #86
adri-13's Avatar
My wheel JACO was old, probably they have find a solution for this problem.
Thank for the tip!
PETITrc driver
www.PETITRC.com
Old 02-10-2012, 05:09 PM   #87
Infinite 12th's Avatar
Tim Copp's X12 (unauthorized pictures) ...lol
Original link
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 03-09-2012, 08:18 AM   #88
Alex C's Avatar
Trader Rating: 50 (100%+)
This thread has been quite for some time, let's start with a few questions and see if I can provide guidance.
All the Best!!!
Alex Cortez
Thank You to all My Sponsors
Ko Propo USA / RC America - Xray - Hudy / Max Power Engines / VP PowerMaster Fuel / Team Espo - "Lay it down Prop"!!!!
Alex C is offline   Reply With Quote
Old 03-09-2012, 01:49 PM   #89
I bought the X12 and assembled it last week and did have some questions.
First off, it is a beautiful car (I'll post pictures soon); looks very nice with the Orion 1S ESC and VST motor. The in-line battery layout is nice in that it provides a lot of space for all the other components to be placed.
The very beginning of the build was rough; when I screwed in the caster mounts to the arms I stripped out the first 3 of 4 screws. Very tight into the plastic, went out and bought a high quality 2mm wrench, new screws, and the rest went clean.
My question is if anyone else has had trouble getting the centerline of the servo armature to line up on the centerline of the car?
I bought the Spektrum H5010 servo (looks like the same specs as the Futaba 9650), but the servo saver’s centerline is not down the center of the car. I would either have to have unequal length turnbuckles (a bad thing) or some awkward shimming of the servo to make it center. I haven’t played yet with flipping it around, and later tonight I’m going to put the calipers on the H5010 and the 9650 to see if the servo armature placements are different, but my eye said the 2 servo’s looked the same.
Also, I bought the Front Active Brace Set (Xray part # 372080) to have an adjustable front end, but the bar is WAY to short to fit across. Does the X12 have a different distance between the front arms than the XII ?
Thanks for your thoughts.
Plan on running it at Chino's TQ Raceway for it's inagural run on Sunday.
Old 03-09-2012, 05:12 PM   #90
Johnny Wishbone's Avatar
I bought the Spektrum H5010 servo (looks like the same specs as the Futaba 9650), but the servo saverís centerline is not down the center of the car. I would either have to have unequal length turnbuckles (a bad thing) or some awkward shimming of the servo to make it center. I havenít played yet with flipping it around, and later tonight Iím going to put the calipers on the H5010 and the 9650 to see if the servo armature placements are different, but my eye said the 2 servoís looked the same.
You should try to mount the servo so the servo saver is in the center of the chassis, that may mean shimming different from side to side.
Yes the X12 is quite a bit wider than the original XII.
Gary Lanzer
New TEAM WAVE racing brushless system TEAMWAVE Electric On-Road 1930 07-25-2014 07:12 AM
XRAY T2'008 US Competition RTR w/lots of upgrades and more - LQQK! jt415gz R/C Items: For Sale/Trade 35 08-06-2010 03:13 PM
LRP Sphere TC - DX3R - X12 4.0T jt415gz Electric On-Road 6 07-06-2009 03:33 PM
