Old 11-18-2011, 11:14 AM   #61
can you please post some pictures of your cars.
Jonsson is offline   Reply With Quote
Old 11-20-2011, 11:48 AM   #62
Originally Posted by EAMotorsports View Post
Yes the preload on the side springs will add more steering and make the car more reactive to steering inputs.
What front springs are you running? Camber? It doenst take a lot of camber to make the car nervous and hard to drive.
I just put my IIC Setup on the xray web page today as well
EA
3.5 front springs and 1,0 camber.
I have tested a bit further - se "version 2" setup on XRAY - Ok, but it was on nearly worn out rear tires. I has a tendency to overturn midturn and out of turns.
Have on new tyres (42/44.5) tried the same set-up but with the soft silver sidesprings, and it worked ok also - no significant changes in the cars behaviour.
Have today tried your frontend (with 5 active caster and 2 mm shim in front and 1+0.5 in back) and 1 degree castor (tires wear flat). Miss a bit of initial turn in, but way better and more controlabel mid turn and out of turns. Overall also a bit more stable and very easy to drive. Overall a bit slower than with the more agressive frontend set-up.
Will on tuesday try with 10k (green tube sponge) in tubes, gold centerspring and sidesprings and see what happens. Also play a little with sidespring load to se how it affect the initial turn in in corners ... and perhaps get the missing amount of turn in that way
Kind regards; Jens
PS. Almost everyone else drive 30k or 40k in tubes and sidespring/centerspring to the hard side at my track - all drive dbPink front and Pink rear - in their cars /Top, BMI Copperhead and Serpent LT).
jensroland is offline   Reply With Quote
Old 11-25-2011, 05:15 PM   #63
Mr.T3's Avatar
Hi, guys never run 12 scale before and thinking about getting one of these just want to know what stuff to run, speedy, servo, tires, body. Any info will be very helpful Thanks.
B-rad
VBC DO8... Sanwa M12... Hudy... Muchmore Racing... Roche...Volante...
Mr.T3 is offline   Reply With Quote
Old 12-15-2011, 07:02 AM   #64
Migigu's Avatar
Thumbs up
Here is my X12
Migigu is offline   Reply With Quote
Old 12-24-2011, 06:35 PM   #65
Car looks great ! Anyone got any build tips?
storminnorm is offline   Reply With Quote
Old 12-26-2011, 05:26 PM   #66
nutsisneat's Avatar
Is it possible to use standard 48 dp spurs on this car? (Kimbrough)
nutsisneat is offline   Reply With Quote
Old 12-27-2011, 09:40 PM   #67
Yes,they work fine...
Old 12-27-2011, 11:41 PM   #68
NR
NR's Avatar
Trader Rating: 52 (100%+)
Is the diff and Axle, the same as the X11, I was going to grab one of these as a spares car. It's costing me $100 so I thought it'd be worth it.
Nathan
NR is offline   Reply With Quote
Old 12-28-2011, 05:41 AM   #69
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Nathan
Yes all those parts are the exact same as the XII.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 12-28-2011, 08:04 PM   #70
Is anyone using the new Spring Steel rear axle yet? Any comments on how it compares to the graphite axles in regards to true-ness, weight, etc?
JamesL_71 is offline   Reply With Quote
Old 12-29-2011, 06:03 PM   #71
aloksatoor's Avatar
Trader Rating: 42 (100%+)
where can you buy it in the states?
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-01-2012, 09:27 AM   #72
Dread Pirate's Avatar
Trader Rating: 15 (100%+)
Stormer has them in stock.
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
Dread Pirate is offline   Reply With Quote
Old 01-01-2012, 09:29 AM   #73
It's getting time to replace my 12L3 / Speedzone saddle pack combo;
For a variety of reasons, the X12 is looking interesting.
I've gone through the manual and have some questions:
1) Are the rear ride height adjustments standard (AE/CRC) or unique to X-Ray?
2) Which front strings come with the kit? The manual lists which come in the kit for the shock and side springs, but doesn't indicate which of the 4 options (gold, silver, black, and/or grey) the kit has in the front.
3) How much pinion range does the motor mount have? The slots look really small, as if not much range. For example: would it handle a pinion range of 15 teeth (64p)?
Thanks.
Old 01-01-2012, 10:24 AM   #74
I'm thinking about getting into 1/12 scale racing and i like the Xray a lot but the kit chassisplate is it suitable for lipo use or do i need to buy another lipo chassis?
And is it a 64 or a 48 pitch for spur/pinion?
Kind regards
addicted2blue is offline   Reply With Quote
Old 01-01-2012, 08:56 PM   #75
Team EAM
1) Are the rear ride height adjustments standard (AE/CRC) or unique to X-Ray? Xray specific.
2) Which front strings come with the kit? The manual lists which come in the kit for the shock and side springs, but doesn't indicate which of the 4 options (gold, silver, black, and/or grey) the kit has in the front. Gold comes in the kit. Its a .019 spring so its in between AE 18 and 20's.
3) How much pinion range does the motor mount have? The slots look really small, as if not much range. For example: would it handle a pinion range of 15 teeth (64p)?It has plenty of adjustment. I dont know xact number but it has not been an issue in any class Ran. I would guess at least 10 teeth.
Thanks.
Kind regards
Its 100% Lipo ready. Nothing else needed! 64 pitch 96 tooth is what comes with it.
EA
Contact Us
New TEAM WAVE racing brushless system TEAMWAVE Electric On-Road 1930 07-25-2014 07:12 AM
XRAY T2'008 US Competition RTR w/lots of upgrades and more - LQQK! jt415gz R/C Items: For Sale/Trade 35 08-06-2010 03:13 PM
LRP Sphere TC - DX3R - X12 4.0T jt415gz Electric On-Road 6 07-06-2009 03:33 PM
