Old 10-02-2011, 04:21 PM   #1
RahjahDat's Avatar
Trader Rating: 101 (98%+)
Default <<<<====New to Electric brushless...Please help guys
I wanted to know a quick expanation of the diffrence in MOTOR KV. like castle 9000KV and 4600KV or mamba monster 2200KV and 2650KV?????What is the diffrence in the examples i gave... Speed? torqe? which is higher and lower speed? is it the lower the kv the better? or the higher?
RahjahDat is offline   Reply With Quote
Old 10-02-2011, 04:43 PM   #2
KV rating means RPM per volt. So if you have a 7.4v LiPo and a 2200KV motor, in theory it should top out at 16,280 rpm. It's related to the number of turns in the motor. More turns mean lower KV. Higher KV motors have fewer turns. The Torque is opposite, the more turns or the lower the KV, the higher the torque of the motor is going to be. If you want a higher torque motor, you go with a low KV, If you want a high speed motor, you would chose a high KV. Neither high or low KV is better than the other, they are just used to accomplish different things. It all depends on what you want.
pensfan2987 is offline   Reply With Quote
Old 10-02-2011, 06:19 PM   #3
RahjahDat's Avatar
Default thanks
thanks alot buddy! ur da man
Ask Frank Root...Losi, Xcelorin, Losi Racing Tires... Frank Root Electric Off-Road 717 11-23-2012 04:04 PM
