Old 10-01-2011, 01:26 PM   #1
Default Gettin back into racing....maybe...'blinky'?
It's been a number years since I've raced. I've been reading and seen 'Blinky'. I've searched and searched and all I can find is blinky mode, and I'm not sure what this is. Can someone explain for me?
rcracerdan is offline   Reply With Quote
Old 10-01-2011, 01:55 PM   #2
Trader Rating: 217 (100%+)
"Blinky" mode is Spec mode. (no timing in ESC) Most speedos have this mode built in as an option.
Andy Koback is offline   Reply With Quote
Old 10-01-2011, 03:33 PM   #3
HarryLeach's Avatar
Send a message via AIM to HarryLeach
There are a lot of up-datable ESC's that have the option to run dynamic timing to the motor to get more top speed out of the car on a gear ratio that allows a lot of acceleration off the corner. These days, this is referred to as "boosted" racing.
Those same ESC's usually have a no-timing mode, and for easy tech they will have an LED, or series of LED's that will blink at neutral throttle to show they are in the spec no-timing mode. This is commonly called "blinky".
There are also some ESC's out that have no timing modes built in, and don't necessarily blink at neutral, but are still legal for "blinky" racing.
A list of the ESC's that are legal, or can be configured to be lega, along with whatever LED display they should have, if required, for Blinky can be found here:
http://www.roarracing.com/?page_id=737
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 10-01-2011, 06:34 PM   #4
I have an older novak brushless system, I don't think it has the timing mode. I'll check out that link.
Old 10-01-2011, 08:07 PM   #5
Most older Novaks are not upgradable but they do have built in throttle profiles which i=are hard to detect by the techs. Best to check where you race if they will allow it. Most probably they will.
AreCee is offline   Reply With Quote
