Old 11-21-2004, 09:41 AM   #1
Default ECS- Auto brake/Neutral Brake/Drag brake
1. which ECS provide tunable and stronge auto brake?
2. how ECSs work to prduce auto brake?
RC12L3a is offline   Reply With Quote
Old 11-21-2004, 11:06 AM   #2
There are several good ESCs available with a drag (auto) brake feature, but my favorite is the Novak Cyclone. With the optional Pit Wizard you can adjust both the frequency (less/more aggressive) and initial amount of braking applied. Other brands have drag brakes, but they may not be as adjustable. Later!
2BAD4ALL is offline   Reply With Quote
Old 11-21-2004, 11:53 AM   #3
Still Bill's Avatar
The LRP Quantum Comp 2 has "automatic brake"; but, I leave mine at a "0" value of the six option settings, being 0-5.
Instead, I dial in any needed drag brake using that function on my radio. It's something that I dial in during practice according to the track conditions.
FYI...As I have become more proficient with my driving, I find that I am using less and less drag brake.
I don't think that automatic brake is a 'reversing function'. I assume that it is more a motor 'shorting function'.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 11-21-2004, 01:06 PM   #4
Bill,
Which radio you are using? and what is the parameter called that you set in your radio to tune drag brake?
Old 11-21-2004, 03:41 PM   #5
You can make adjustments on most radios that will give a similar feel, but most ESCs manufacturers say it isn't as effective or as fine tuned as making adjustments on an ESC. It's basically adding negative throttle exponential.
Old 11-21-2004, 08:50 PM   #6
Still Bill's Avatar
Originally posted by RC12L3a
Bill,
I use the JR Racing XS3 75 MHz synthesized radio. Use Grip Lever A to adjust Brake End-Point Adjustment which ends up being a drag brake. I am usually in the 15-30% value range depending on the situation.
Old 11-21-2004, 10:10 PM   #7
thanks all
Drag Brake Bandeira Nitro On-Road 8 07-31-2009 05:13 PM
3pk drag brake Nitro Herb Radio and Electronics 3 01-09-2008 07:00 PM
Drag Brake alan Nitro On-Road 9 10-27-2005 09:49 PM
drag brake, brake and reverse imjonah Rookie Zone 3 07-24-2004 07:20 PM
Drag brake Peter Busch Electric On-Road 7 06-26-2002 11:54 PM
