Old 09-30-2011, 05:50 PM   #1
Default Esc keeps going into sensorless mode! please help
for the last 4 weeks ive been running my hobbywing xerun 2.0 60 amp speedo with a duo 2 10.5 motor . i have an intermittent fault where the esc goes into sensorless mode during the 5 min run . ive changed the sensor board and the cable , but it still does it .
anyone got any ideas ,only seems to happen when running more than 30 boost ,hobby wing say this esc can run down to a 5.5 motor
vwvrt is offline   Reply With Quote
Old 10-01-2011, 01:29 AM   #2
you should move this post to the HW one so to get more views and answers, what is your software version?
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 10-01-2011, 03:27 AM   #3
Old 10-01-2011, 03:40 AM   #4
give us your full setup, fdr and after how many minutes does it go into sensorless?
Did you try to reload the software or update it?
Old 10-01-2011, 08:09 PM   #5
JKL1031's Avatar
switch wires again.
China Lipos
China Speedos
China Chargers
You aint messin wit my dougie..
JKL1031 is offline   Reply With Quote
Old 10-03-2011, 06:39 PM   #6
Wall Banger's Avatar
Between the esc and the motor there is to much timing. either take timing from the motor or from the esc.
Wall Banger is offline   Reply With Quote
Old 10-04-2011, 12:54 AM   #7
im running 35 boost and the motor is on the first mark after 0 so 16 degs .fdr 8.0. so its only medium settings it doesnt get hot at all.
Old 10-04-2011, 01:27 AM   #8
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
i would recommend going to the hobbywing thread, but as far as i remember, this was always a problem with the software being to narrow in the sensortiming. and with some motors the esc looses the rotor position then and switches into sensorless mode. i think in the hobbywing thread cobra posted a updated 211 software with is less narrow on the sensors so it should work with really any motor.
Infinity -- Orion ESC -- Sanwa M11x
May the grip be with you ... always!
vitomon is offline   Reply With Quote
Old 10-04-2011, 08:47 AM   #9
Try zero timing on the motor. if that solves the problem. I had the same problem with a D2 with two different esc from two different manufacturers.
I changed motors and no more probelm.
The SC10 4x4 Guide CraigV Electric Off-Road 9 09-10-2014 11:00 PM
