Old 09-30-2011, 03:04 PM   #1
WheelNut's Avatar
Send a message via MSN to WheelNut
Default TC: FDR for 17.5 non-boost
Quick question: First time running unboosted 17.5 in touring car on a medium sized carpet track with rubber tires. What FDR should I start with?
Thanks!
WheelNut is offline   Reply With Quote
Old 09-30-2011, 03:19 PM   #2
Regional Moderator
Jim Herrmann's Avatar
Four.
Jim Herrmann, ex-Professional (turned Life Coach)
Jim Herrmann is offline   Reply With Quote
Old 09-30-2011, 03:20 PM   #3
Magnet Top's Avatar
You'll need to post what motor you are using to get an good answer !!! But without any info I'll throw out a guess for a starting point !!! Try 4.0 and check your temperature EVERY minute for a 6 minute run. If the temp is over 170 you should adjust so you will not ruin your motor. High temperature does not mean you have found the optimal gearing for your particular track layout !!!
goodluck
Magnet Top is offline   Reply With Quote
Old 09-30-2011, 03:35 PM   #4
WheelNut's Avatar
It's a Speed Passion Feigao motor- about 3 years old. I'll probably start with a 4.5 and work my way down from there.
Update: Hmmm, well, it looks like the biggest gears I've got put me at 4.75. So, hopefully that's not too slow, but it's only a club race, so I'll survive.
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
Richfield Raceway in Central PA Victory Side Mid Atlantic RC Racing 5851 11-03-2017 06:05 AM
MurfDogg Motor Works Discussion thread The MurfDogg Team and Company Discussions 1382 12-08-2014 06:38 PM
Nemesis 17.5 motor thread windsor Electric On-Road 133 01-07-2011 02:53 PM
