Old 09-30-2011, 05:08 AM   #1
wollow86's Avatar
Default Carpet rubber tyres.
Ok, need some help oh wise forum.
One of the local clubs I race at is using foam on indoor carpet. Which to be honest i've found to be nothing more then an expensive pain in the arse. So I want to swap to rubber tyres, which they insist they haven't been able to get to work, and because I don't have a lot of money to try a bunch of different compounds on rubber just to have heaps of tyres I cant use, I have yet to try them.
The foams I've been using have been around the 35sh fronts and 32/30sh rear, but some members have been using up to 42sh fronts with 37/35 rears. And this provides a pretty good amount of grip.
The surface isn't normal carpet, but astro turf. Its worn down a lot, so it has the look and feel of carpet. It can be very dusty, the car often comes of the track coated in green fiber dust, after a while it even gets into the ball diffs. As it is primarily an indoor soccer field, we aren't allowed any type of traction compound.
The chassis is a Schumacher mi1, running Schumacher white springs all round (14lb) front and rear sway bars, about 5mm ride height. Running in 17.5 boosted. Track layout changes every 3 meets. Typically one good straight, then technical infield, maybe second shorter straight. Obviously, size is an indoor soccer field. If you need more setup info that will help ask away.
Any help would be great. Mainly looking for a starting point, or a tyre that will work well on low grip carpet.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 09-30-2011, 08:12 AM   #2
I don't know with astroturf, but the best tire for carpet I have used so far, is Sorex 28.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 09-30-2011, 08:26 AM   #3
locked's Avatar
Difficult to find traction on a dusty surface. Sorex are awesome on any clean surface, but even the best slicks aren't good if it's really dusty like you are describing. You'll probably find Schumacher mini pin tires or Tamiya rally block tires will hook up better than slicks.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 09-30-2011, 09:17 AM   #4
jsinclair's Avatar
I second the use of the rally blocks, I have run them in the past on dusty astro turf on my traxxas rally vxl. There the best tire I've found for this application, and they don't want to wear out.
jsinclair is offline   Reply With Quote
Old 09-30-2011, 04:35 PM   #5
TeamWTF's Avatar
Setup wise I'd raise the car to around 6mm to handle the bumps...
Tire wise... We tried using the SWEEP EXP 30 tires and they worked ok. Obviously slower then foam but still fine to get around with (MRJ has some stock if we get interested again)
I like the Shui pin idea... and the Blocks. They may work in stock but would they hold up in modified?
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 09-30-2011, 07:24 PM   #6
wingracer's Avatar
Trader Rating: 24 (100%+)
I've run on fresh turf before. Rally style tires worked pretty well.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 09-30-2011, 08:53 PM   #7
wollow86's Avatar
Frontline actually have the mini pins in stock too. I saw them last time I was in there. What inserts should be used with them?
I'll try the heigher ride height too, I'm a little limited with my shocks cause they use spacers rather then threaded collars. I don't really want to spend $80-$100 on new shocks either cos I plan on getting a new chassis in 6 months or so anyway.
Old 09-30-2011, 09:03 PM   #8
You can pick up 3racing or Yeah Racing shocks pretty cheaply from rcmart. .....
Racing program on # pause #
RedBullRacing is offline   Reply With Quote
Old 09-30-2011, 09:07 PM   #9
wollow86's Avatar
I tried yeah racing on the mini and didn't like them. The trf were heaps better. So I'd be worried that they wouldn't work as well as the stock shui ones even with the better ride height adjustment.
Xray T2 009 carpet setup with rubber tyres FLAT OUT Electric On-Road 13 09-27-2009 12:57 PM
Future of rubber tyres for Electric touring cars frozenpod Australian Racing 35 02-10-2009 06:14 PM
how to glue rubber tyres? Stevie Rookie Zone 6 05-04-2003 06:24 PM
