Old 11-20-2004, 06:32 PM   #1
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
Default LRP Pulsar Comp charger question
i just got a pulsar comp(1) charger and i feel like an idiot but i dont know how to power it? it just has alligator clips, do i have to run a power supply for it? or is there a way i can just plug it to a standard house outlet?
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 11-20-2004, 06:33 PM   #2
you need a power supply.
mtc3od is offline   Reply With Quote
Old 11-20-2004, 06:36 PM   #3
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
You'll need a 12v power supply. Make sure it puts out enough amperage. I'd say get one with 15 amps at least. That way won't be pushing it when you want to break in motors.
Jon Kerr is offline   Reply With Quote
Old 11-20-2004, 06:42 PM   #4
rdub202's Avatar
what is a good relatively inexpensive one? how much do they average running for?
darn i didnt think i was going to have to spend more money
Old 11-20-2004, 07:01 PM   #5
ChadCapece's Avatar
This may be piss off the lrp guys, but I'm using a Novak N-power. Its a 14v with 10 amps. I haven;t had a motor pull over ten amps on break-in. My mods pull about 4 amps at 3 volts w. fan. My stocks pull 7 amps w. fan.
ChadCapece is offline   Reply With Quote
Old 11-20-2004, 07:39 PM   #6
rdub202's Avatar
thanks
Old 11-20-2004, 08:56 PM   #7
Jon Kerr's Avatar
I run mine off a 10 amp PS too but I'm going to get a larger one so that I can run multiple things without worrying (Turbo 35, LRP Comp, Equalizing tray, etc...)
Old 11-21-2004, 04:21 AM   #8
J-P
J-P's Avatar
you could just use a 12volt car battery or 12volt leisure battery
J-P
J-P is offline   Reply With Quote
Old 11-21-2004, 06:58 AM   #9
Just connect it to a 12v car or leisure battery like J-P said, that's all i do, i do that with my lathe as well and when i had a 12v soldering iron (need to get another one of those soon )
Chazz
Chazz is offline   Reply With Quote
Old 11-21-2004, 09:08 AM   #10
rdub202's Avatar
it would last a long time wouldnt it?
Old 11-21-2004, 09:21 AM   #11
Jon Kerr's Avatar
I've used 12 car batts for power at parking lot races for a long time. They'll last about 8-10 charges before the charger will be lacking on input voltage. The LRP is very efficiant and will get you more charges than most chargers off a car battery.
Old 11-21-2004, 09:47 AM   #12
rdub202's Avatar
is there a certain kind of battery i am looking for?
looks like they are giong to be around the same price i coudl get a power supply on here for...
Old 11-21-2004, 09:53 AM   #13
Also you'll need a 12v battery charger (if you haven't worked that out ) for after the meeting when you get home
Old 11-21-2004, 09:56 AM   #14
rdub202's Avatar
ill just get an N-power just easier and u dont have to charge it and whatever and they are like the same price
thanks everyone
(500th post by the way... )
Old 02-15-2005, 07:58 PM   #15
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Thinking of getting a LRP Pulsar 1 and I wanted to know what settings are used for the delta peak? I heard it has 5mV to 60mV and I'm kinda confused since it doesn't have the delta fall back in .01 through .05 and so on.
I would appreciate any help.
EA Motorsports
picco007 is offline   Reply With Quote
F/S LRP Pulsar Comp Charger drifterrolly R/C Items: For Sale/Trade 7 11-04-2007 07:56 PM
f/s lrp comp pulsar charger rcnutmich R/C Items: For Sale/Trade 1 12-01-2005 05:48 AM
Lrp Pulsar Comp Charger TheTurtleMan R/C Items: For Sale/Trade 19 02-03-2005 08:11 PM
F/S: LRP Pulsar Comp Charger Hebiki R/C Items: For Sale/Trade 19 01-13-2005 12:34 AM
LRP Pulsar Comp - Question / Problem? rctoyguy Electric On-Road 6 09-14-2004 02:06 PM
