Old 11-19-2004, 08:52 PM   #1
Send a message via ICQ to tc3Guru Send a message via AIM to tc3Guru
Default 28MM tc4
yo i just picked up some foams for my tc4. 28mm and they rub like a ho in heat.. is 30MM all i can run????
tc3Guru is offline   Reply With Quote
Old 11-19-2004, 09:35 PM   #2
Joel Lagace's Avatar
If your running 30mm then you can run 28 or 26mm.
Most TC3s will run 30mm in the rear and 26-28mm in the front maybe with some dremel work
28rear 26front should go without modification.
Really depends on shock mount positions in most cases
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 11-20-2004, 01:44 AM   #3
Chill Will's Avatar
Default Re: 28MM tc4
If you are running 28mm and they rub, 30mm will be worst. Thats if you mean they are rubbing the front shock when you turn. If so you will need to run with the shock in the inside hole on the arm. When brand tires are you running. Some brand wheels are taller than others.
Chill Will is offline   Reply With Quote
Old 11-20-2004, 05:51 AM   #4
CRASH's Avatar
Trader Rating: 26 (100%+)
Default 28mm Tires Rub
They should only rub on the front steering blocks. Rear hub carrier should be fine. You just need to get some thin washers to space the wheel out and you are good to go. The thin white HPI spacers are the best.
Later,
CRASH is offline   Reply With Quote
Old 11-20-2004, 06:13 AM   #5
Send a message via AIM to Javen13 Send a message via Yahoo to Javen13
yeah 28mm do rub you have to slightly file down the front carriers and dual rate if they rub the shock to
Javen13 is offline   Reply With Quote
Old 11-20-2004, 06:16 AM   #6
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Or you could just cut a little off them like I did.....
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 11-21-2004, 01:22 AM   #7
Default Re: Re: 28MM tc4
lol i was so tired putting that thing together lastnite in prep today to race. i mean i can't run 30shore on rear. @ all. tried cuttin down the ballcup a little but cut too much and put it back on there so i ran 28 all the way around. You guys come up w/ something to run 30mm on the rear let me know.
is it losi hubcarriers some ppl or run. hell i can't remember. lol.
Old 11-21-2004, 01:45 AM   #8
Speedie's Avatar
Are you running on asphalt or on carpet?
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Lot of Jaco 28mm Sedan Prism tires.28mm dish wheels. and 26mm wagon wheels. samstheman2 R/C Items: For Sale/Trade 15 11-23-2007 09:15 PM
WTB: TRC 28mm Foams Nexus R/C Items: Wanted to Buy 0 07-09-2006 02:58 PM
TRC 28mm Foams... Nexus Electric On-Road 0 07-09-2006 02:56 PM
NIB 28mm TC Tires Tres R/C Items: For Sale/Trade 2 10-18-2005 06:43 PM
26 or 28mm foams..? dasupacat Electric On-Road 4 10-04-2004 04:41 PM
