Old 11-06-2013, 06:56 AM   #211
Originally Posted by OVA View Post
Hey Redbullfixx
question; I'm thinking about getting the Rev8 conversion WGT
There's something I need to get..I don't own the wgt..but I do have the comnplete rear axles and old skool front end and rear pod mount and rev5 rear motor mount ..thanks
Do you think the R5 front end is good as the Old skool for stock racing ?
Are you trying to build a WGT3? You have a worldGT axle set? The right hub offset like this one?
Sounds like to me your best option would be getting a WGT3 'custom' kit. It is a kit without the rear axle, front end, and shock. To me it sounds like you already have those.
JoelV is offline   Reply With Quote
Old 11-06-2013, 09:07 AM   #212
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
I will check as soon I get home from work..Thanks
OVA is offline   Reply With Quote
Old 11-06-2013, 03:49 PM   #213
Suspended
I like it, congrats
http://www.timesharescam.com/
emabrown is offline   Reply With Quote
Old 11-06-2013, 05:21 PM   #214
OVA
OVA's Avatar
Anyone want to sell their WGT please PM thanks
Old 11-06-2013, 07:32 PM   #215
avs
avs's Avatar
so is a Rev8 wgt mod available? (or a Rev8 kit?)
Tony Shimko
avs is offline   Reply With Quote
Old 11-08-2013, 09:05 AM   #216
I am unsure what you are asking. Between 12th scale and WGT they share shock,pod plates, front end, hardware. You would still need graphite, axles/hubs to convert a car between the two, which at that point its worth just getting a complete kit.
Rev 8 full kits have been waiting on rear axles and hubs which IRS has been backed up with.
Old 11-08-2013, 09:11 AM   #217
R Dodge's Avatar
Joel, I want you to personally deliver my cars. Do it on a Sunday so you, me and X can catch a Ravens loss together.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 11-09-2013, 07:50 AM   #218
avs
avs's Avatar
sorry, i was asking (awkwardly) if a WGT4 was coming soon.
Tony Shimko
Old 11-11-2013, 10:08 AM   #219
NutDriver's Avatar
Trader Rating: 19 (100%+)
Just bought a used Speed Merchant car from YR4Dude. Sent pics to Bruce to see what I had. He responded at 4:00am!! Get some sleep, Bruce!! (To see pics of my Frankenstein Speed Merchant, check YR4Dude's WGT album here on RCtech)
I'm hoping to receive the car later this week and get to Bush River Raceway in Columbia, SC to mix it up with the CRCs there.
Scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 11-15-2013, 12:12 PM   #220
NutDriver's Avatar
Would anyone be so kind as to share a baseline setup for the car or direct me to where I can find one?
Scott
USVTA member #111
Old 11-15-2013, 01:56 PM   #221
303slowdown's Avatar
Trader Rating: 24 (100%+)
Ride height 4mm all around
.20 front springs ( if not running old skool front-end ,5deg dinamic caster, thin caster shim forward ,.1deg negative camber)
20000 diff lube on king pins
.20 side springs ( just touching pod)
Green tube spooge in side tubes ( if you don't have tube spooge 15000 diff lube)
Gold or blue center shock spring
35wt shock oil
0 pod droop
0 chassis sag
This is what I always start with for a base setup and usually only change a couple things to dial it in.
Hope this helps.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 11-15-2013, 07:31 PM   #222
NutDriver's Avatar
Awesome. Thanks, Ryan. I'll have to get in touch with Bruce, etc and get the green spooge, etc.
USVTA member #111
Old 11-15-2013, 09:02 PM   #223
NutDriver's Avatar
Just ordered the front and side springs and the green spooge. Didn't see the gold or blue center shock springs.
Scott
USVTA member #111
Old 11-15-2013, 11:39 PM   #224
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
They are AE parts I think if that helps.
AWD
Old 11-16-2013, 08:30 AM   #225
NutDriver's Avatar
The guy behind Slapmaster has been posting on the 1/12th scale forum and has done what seems to be some extensive work in testing springs. I'll go and find the link and post it here. Might be handy.
USVTA member #111
