Old 11-18-2004, 11:09 PM   #1
jackfast's Avatar
Default Battery Resistance
I am cycling all my packs tonight, mainly my fukuyamas, and a pack of trinity VIS cells that I just bought. I was wondering what level of resistance everyone else is reading on their race packs to see if I am withing the range of resitance.
I always charge the same using 6amps and the lowest peak detection setting that I can use to prolong the life of my packs. Anyone else have any resistance remarks you can make? What are your readings on some of your best packs?
jackfast is offline   Reply With Quote
Old 11-18-2004, 11:51 PM   #2
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
Wat charger are you using?
Different charger gives you different reading. To share with you, my CDC v6.0B gives an avarage of 25 mohm to 36 mohm
AdR|aN is offline   Reply With Quote
Old 11-18-2004, 11:57 PM   #3
jackfast's Avatar
I am using the integy 16x5x6, and I am getting around the same results as you. The highest I usually see is about 36ohms. I just didn't have any figures to compare to so I was kind of wondering.
Old 11-19-2004, 04:58 AM   #4
Send a message via AIM to (V)r>??@uD@ Send a message via Yahoo to (V)r>??@uD@
Default non matched batts
i have gp3300 stick packs but i cut them up and made them into saddle ()()()()()() i was wondering is it ok to get a high 40 to low 50s resistance and there not matched or anything
(V)r>??@uD@ is offline   Reply With Quote
Ps3: Resistance Fall of Man DaveW Chat Lounge 2 08-08-2007 06:58 PM
BAttery Resistance Question jeffbhhs Electric On-Road 4 01-24-2007 02:11 PM
How do you measure the interal resistance of a battery? bvoltz Rookie Zone 14 09-22-2005 01:38 AM
ON-resistance tomdav Electric On-Road 3 01-16-2004 01:24 AM
Measuring battery internal resistance Cole Trickle Electric On-Road 2 12-20-2001 02:13 AM
