Xray T3 2012
#1097
So got to run my 12 today all I can say is awesome! Box stock set up rocked. One quick question what should I change on it if the rear is a little little lose? Medium to high bite track.1k in the rear.I'm just wondering what every one is running for set up's.
Thanks jeff.
Thanks jeff.
#1098
Thanks jeff.
Thanks jeff.
#1099
Hi Cristian,
I snapped a belt at FEMCA, brand new, and it was the first one I've ever done. Brian (a mate) has gone through 3 in a very short time. We ended up running a bit more tension then what we were normally running.
I put this down to the gear diffs. The Diffs have no give (unlike the ball diffs).
The drive line unloads (forwhatever reason) then grips, this shock, that used to be absorbed by the ball diff is now taken by the belt... which only stretches so far...
Mark
Mark
#1101
No problem (loose belts) so mabye u have tightened them so much
#1102
http://www.toughracing.com/zc126d/in...ndex&cPath=161
#1103
The belt napping is probably related as much to driving technique as it is setup. I've not managed to snap a belt since September, racing is similar high grip environments and just being careful with throttle applications.
What sort of motor/track conditions do you race in?
#1104
hey guys,
I also finished my new t3 '12 last week, now everything is setup but didn't have a chance to test the car yet. However the parts quality is awesome and booklet is clear, I really liked it.
I have only one question, the rear small AL. bulks which gives the toe in.. During the assambly of it when I screwed these small bulks, I recognized that they move a little which changes the rear toe angle..After the assambly I found out that the rear right toe in is 3mm and rear left toe in is 2.5mm ..I am sure that I assambled everything correct way double checked already.. There is some variation I guess, have you guys seen such issue or is it normal?
Many thanks in advance.
#1105
hey guys,
I cheated and just put the right shims in each side to get what I wanted, not what the manual say's
Now have perfect 3deg each side lol
#1106
Just my two cents.
- Emil
#1107
Xray plastic is so durable I don't see any need to change out any of the plastic in the car (not even the shock bodies).
#1108
#1109
hey guys,
thanks jeff.
#1110
I also found the problem with the rear toe using Integy's system which I had before.
