Like Tree1Likes
Xray T3 2012
Old 11-26-2011, 09:17 AM
  #721
Default slop in turnbuckles
Hi,
Ive just bought a t3 12 and i notice that straight out the box there is a fare amount of slop in all the turnbuckles! Is it good to have a bit of slop or are there different ball joints or cups from another make of car that can be used to get rid of this??
Matt W is offline
Old 11-26-2011, 06:58 PM
  #722
SLOW 77's Avatar
Trader Rating: 31 (100%+)
Originally Posted by P.I.M.P
hi lads,
i run the "12" tonight, car felt great with minor changes only in stock "blinky mode tho" but still handles good only thing is xray needs to sort out supplying 50mm drive shafts in the kit for the rear.i trimmed the swing shaft protector thinking it would help which it did but still was not getting the travel i needed in the rear arms.it was stepping out in the rear then i put 50mm drive shaft in and problem fix rear not stepping out. i could only accomplish 3_4mm travel with 3deg toe and with 2deg camber with trimmed protector.
I agree with this as well, please start putting 50mm rear shafts in standard.
SLOW 77 is offline
Old 11-26-2011, 06:59 PM
  #723
rcguy48's Avatar
Hi guys I am getting a T3 12 and i was wondering what is a good motor to get for it.
rcguy48 is offline
Old 11-26-2011, 07:04 PM
  #724
haywood's Avatar
Trader Rating: 49 (100%+)
Need more info! Stock or mod? Boosted or Blinkey?
haywood is offline
Old 11-26-2011, 07:05 PM
  #725
rcguy48's Avatar
just a stock motor. I want a 17.5t
rcguy48 is offline
Old 11-26-2011, 07:09 PM
  #726
haywood's Avatar
Default 17.5
Revtech!
haywood is offline
Old 11-26-2011, 07:10 PM
  #727
rcguy48's Avatar
ok thanks
rcguy48 is offline
Old 11-26-2011, 07:13 PM
  #728
Trader Rating: 46 (100%+)
ok thanks
dont run revtech there slow talk to erik at the track and he will hook you up with what you want or talk to the guys at the track and see what there running hell come over and see me all i run is speed passion
transplantlife is offline
Old 11-26-2011, 07:14 PM
  #729
rcguy48's Avatar
ok thanks. what are the good speed passions i heard that they are good.
rcguy48 is offline
Old 11-26-2011, 07:16 PM
  #730
MMM is what you want if you go with speed passion with 30 degree timiing board!
P.S. come out tomorrow if you can its sunday funday racing..
Old 11-26-2011, 07:18 PM
  #731
haywood's Avatar
Default 17.5
Speed Passion... That's a good one! You want advice from this guy?
Transplantlife speaking!
http://www.beamish.com/files/VoiceMailLeftBySeller.mp3
haywood is offline
Old 11-26-2011, 07:19 PM
  #732
rcguy48's Avatar
Ok and what is the track called is it carpet?
rcguy48 is offline
Old 11-26-2011, 07:22 PM
  #733
Yes its carpet or are you going to underground?
Old 11-26-2011, 07:23 PM
  #734
rcguy48's Avatar
what is the track called that you go to.
rcguy48 is offline
Old 11-27-2011, 07:14 AM
  #735
For stock, only one motor to get (if you can get one) corally pro red. Miles miles faster than anything else out there!!
Mb3195 is offline
