Like Tree1Likes
Xray T3 2012
Old 02-17-2013, 06:04 PM
  #4051
nerdling's Avatar
Originally Posted by jgraham37128
I run 17.5 blinky with rubber tire and always use 96-104 spur gear. Why are you using such a small spur gear? Is it a small track? Maybe you need larger pinions?
I'm running a 54t pinion and a 104t spur. I'm out of space for increasing the size of the pinion gear.
The need for the smaller spur/larger pinion comes from the tires wearing down. I'm down to about 58mm.
nerdling is offline
Old 02-17-2013, 07:25 PM
  #4052
Smaller spurs give more room to change FDR, 3.8-4.0 is usually what I run for 17.5 a 4.0 is a 4.0 no matter what size spur and pinion IMO
JOE SI is offline
Old 02-18-2013, 11:34 AM
  #4053
Trader Rating: 70 (100%+)
In your first post you said you are using xrays smallest 64p, but here you say you are using 104. Are you aware they go down to 92? PN XRA305862
PROMODVETTE is offline
Old 02-18-2013, 11:52 PM
  #4054
nerdling's Avatar
No I wasn't. Thanks for the heads up.
nerdling is offline
Old 02-19-2013, 07:10 PM
  #4055
jag88's Avatar
I need some help. I'm trying to find a part number for the Xray progressive spring (not short spring) that would be the next hardest up from the progressive spring #308372 (2.2 - 2.6). I'm thinking it would probably be in the range of 2.6 to 3.0 ???
I've looked on the Xray website but all I can find is the 2.2 - 2.6 spring.
I'm beginning to think that they never released one.
Thanks.
jag88 is offline
Old 02-19-2013, 07:25 PM
  #4056
Josh-n-ya's Avatar
Trader Rating: 95 (100%+)
Thanks.
There is a 2.8! I have one on my car. Bought it used so I dont know where it came from, sorry!
Josh-n-ya is offline
Old 02-20-2013, 07:15 AM
  #4057
jag88's Avatar
Thanks for the reply. Just wondering if the progressive springs are laser etched any differently then the non progressive springs.
Thanks again.
jag88 is offline
Old 02-20-2013, 08:36 AM
  #4058
Skiddins's Avatar
Thanks again.
The Xray progressives are laser etched with both numbers and (i think) a dash inbetween.
I don't recall any other 'long' springs apart from the 2.2-2.6
The newer short springs have 2.3-2.6 and 2.5-2.8
Skiddins
Skiddins is offline
Old 02-20-2013, 08:47 AM
  #4059
jag88's Avatar
Skiddins
Thanks Skiddins.
jag88 is offline
Old 03-04-2013, 07:20 PM
  #4060
FastPete's Avatar
Trader Rating: 44 (100%+)
I did some searching and a few monhs ago there were still some new 2012 kits around. I dont see any now. Anyone know of any? new im talking.
FastPete is offline
Old 03-12-2013, 10:34 PM
  #4061
Josh-n-ya's Avatar
Default 13.5 gearing
17.5 is around 3.8 to 4.0! What would be good for 13.5 blinky?
Old 03-13-2013, 02:56 AM
  #4062
Skiddins's Avatar
AT my club 30m*16m it's 4.5-4.7fdr
Skiddins is offline
Old 03-13-2013, 06:43 AM
  #4063
Josh-n-ya's Avatar
Thank you! I was thinking a little higher from the 17.5 gearing. Sounds good!
Old 03-14-2013, 11:36 AM
  #4064
Default Substitute front c hub bushings
I need one of those front c hub bushings, part #XRA302291, for this weekend. I can't get the part (without great expense) before the weekend. I was wondering if some one had any luck with some kind of temporary substitute? Maybe some brass or aluminum tubing from the hardware store and a washer/spacer? Maybe a part from another brand car?
I did a search about this, but found no entries.
Rufus2010 is offline
Old 03-14-2013, 01:56 PM
  #4065
vivo quevas's Avatar
Trader Rating: 19 (100%+)
I used a tc6.1 you have to ream the c carrier out a Llittle but it will work!
vivo quevas is offline
