Like Tree1Likes
Xray T3 2012
Old 07-26-2012, 05:12 PM
  #3241
Paul is running a new servo mount on his car.. pretty much the same idea as the option servo mount but now attached to two points on the inside of the chassis behind the servo instead of mounting it to the steering post.
So when they release it, we get to change our "old" new servo mount or else why release that mount, if it supposed the be working? that will be the question..
JanE is offline
Old 07-26-2012, 05:20 PM
  #3242
Fred Hubbard's Avatar
I'm 99% cetain that you will not be able to swap the current version for a new version. This is an option part which isn't a necessity in order to run the car.
Fred Hubbard is offline
Old 07-26-2012, 05:45 PM
  #3243
silvalis's Avatar
Trader Rating: 29 (100%+)
hmm. I recall having the same issue - 20% difference in balance L/R. A servo swap or two later and repeated fiddling, I only got down to '10' subtrim, 10% difference (70/80% L/R) and a link length of 16.4mm (shortest i could get it).
silvalis is offline
Old 07-26-2012, 06:00 PM
  #3244
haywood's Avatar
Trader Rating: 49 (100%+)
Default Servo
I think this servo mount drama is overrated! I have not lost a race yet because my servo mount wasn't somehow modded or the other guy had his servo mounted better! I usually take the lead then 4 minutes in park it!
haywood is offline
Old 07-26-2012, 06:35 PM
  #3245
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Is this because your poorly mounted servo moves to where you are forced to hold the wheel full lock left going down the straight away?
Ron Goetter is offline
Old 07-28-2012, 12:48 AM
  #3246
andrewdoherty's Avatar
http://www.rc50.com/modules.php?name...974&fullsize=1
Some interesting Xray stuff.
andrewdoherty is offline
Old 07-28-2012, 01:34 AM
  #3247
NR
NR's Avatar
Trader Rating: 52 (100%+)
Originally Posted by andrewdoherty
Looks like Meen's car, it's so disappointing this worlds as we will never really gauge where the X-ray is in terms of competitiveness and weather or not the new parts do the car justice.
Servo mount looks rather interesting, don't know about the short shocks, and is it just me or are those shock towers really thick?
Nathan
NR is offline
Old 07-28-2012, 04:56 AM
  #3248
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
Motor mount looks nice. Wish I could see the servo mount better
Jamison R is offline
Old 07-28-2012, 05:46 AM
  #3249
defcone's Avatar
Trader Rating: 15 (100%+)
The suspension mounts look really weird as well, looks like they moved the entire wheelbase forward?
defcone is offline
Old 07-28-2012, 06:17 AM
  #3250
B4james's Avatar
And finally split blocks that have two screws supporting them - yippee no more risk of a cracked chassis
B4james is offline
Old 07-28-2012, 06:51 AM
  #3251
Skiddins's Avatar
How did you find that pic?
Skiddins is offline
Old 07-28-2012, 07:12 AM
  #3252
MikeXray's Avatar
Trader Rating: 73 (100%+)
the arms look straighter too
MikeXray is offline
Old 07-28-2012, 09:01 AM
  #3253
I was just randomly poking through Nash's pics on rc50.com.
Old 07-28-2012, 09:11 AM
  #3254
Skiddins's Avatar
The things that I think Ican see that are different include;
Shocks (shorter)
Shock towers
Servo mount
Motor mount
Layshaft mount
Chassis
Top deck (must be different due to some of the above)
Pivot Block mounts, front and rear
Bulkheads closer together
Narrower Gear Diff, see bulkheads
Narrower Spool, see bulkheads
Ackermann Centre link
Option, steering arms
They look the same to me.
Once again, the 'corners' would appear to be the same.
I reckon that's around 50% of the components that different.
And if I'm right about the bulkheads being narrower, then the entire car will be at least a couple of mm narrower overall.
Skiddins
Skiddins is offline
Old 07-28-2012, 09:21 AM
  #3255
Super Moderator
Slo_E4's Avatar
Trader Rating: 62 (100%+)
Rear anti roll bar holders are on top of the lower bulkheads.
Slo_E4 is offline
