Xray T3 2012
#3092
#3093
"This mod makes the rear of the car quite a lot narrower which results in more turn-in and mid corner rotation. The car will be more aggressive and difficult to drive but faster for some conditions."
#3094
I read somewhere that he made the modification to get a shorter rear camber link which helps give more steering.
#3095
But based on what Hagberg has said about the mod to me it suggests more steering which would be less rear grip:
#3098
I wasted money buying gears before I realized that certain gear combos just wont fit into the T3 so I decided to make my own chart which clearly shows which gear combos fit and which don't. Thought I would share.
It should be fairly accurate, I test fit several different gears and then extrapolated the rest of the chart from there.
Last edited by Qwiglee; 07-11-2012 at 08:58 AM. Reason: Revised the gear chart for accuracy
#3099
Awesome, just a sanity check everything in pink doesn't fit correct?
#3100
#3101
If you can confirm this for sure, let me know and I can adjust the chart. I have those gears so I can double check this when I get home tonight.
Yes
Yes
#3102
Not raced for 12 years, so learning curve again.
Basic question for you guys for this Xray T3 2012 kit.
Instructions state using a thread lock at certain points, what brands work well these days and what is generally suitable for all kits?
(I also just got a F104 kit).
As the chassis are carbon fibre (new to me) just want to make sure thread locks that won't cause chemical issues etc.
Most important thing though is a good thread lock that works so your car doesn't fall apart!
#3103
