Like Tree1Likes
Xray T3 2012
Old 07-03-2012, 06:46 PM
  #3061
bvoltz's Avatar
Trader Rating: 44 (100%+)
Originally Posted by casino57
This babboon is starting to get the hang of it!
So are we now calling you Bubbles?
bvoltz is offline
Old 07-03-2012, 06:50 PM
  #3062
bvoltz's Avatar
Originally Posted by NolanP
I can vouch for that. Aren't you supposed to be getting slower as you get older?
No, just smoother..... which is faster.....
bvoltz is offline
Old 07-03-2012, 06:58 PM
  #3063
NolanP's Avatar
true.....just need to catch up by august.
NolanP is offline
Old 07-03-2012, 07:26 PM
  #3064
NolanP's Avatar
Just curious on how quick this thing will sell.
http://www.superiorhobbies.com/istar...=XRA301133!SER
NolanP is offline
Old 07-04-2012, 09:03 PM
  #3065
I'm still thinking how antiroll bar can affect handling characteristic. It's true that it can lift the arm on the opposite side, but when i attached the shock, even 1.6 bar and the softest spring, it can't move the other side at all.
b.wihardja is offline
Old 07-04-2012, 09:37 PM
  #3066
Xpress's Avatar
The anti-roll bar does not have to "lift" the other arm to be functional. Take both shocks off one end of the car and lift one of the arms. Take notice how easily the arm lifts. Now, hold one of the arms down and try to lift the other one. You should notice a difference in the amount of force needed to lift the arm.
Xpress is offline
Old 07-04-2012, 11:02 PM
  #3067
RCknight's Avatar
I can't understand why no could have taken a photo of the new X-ray parts. Can someone pm them to me? I won't forward them. Thx
RCknight is offline
Old 07-05-2012, 01:24 AM
  #3068
Skiddins's Avatar
Probably because they were asked not to. They aren't new parts, they are prototype parts, that's not the same thing.
Skiddins is offline
Old 07-05-2012, 11:10 AM
  #3069
Qwiglee's Avatar
I was wondering what is the safest way to clean the oil out of a diff to get it ready for new oil? I have a diff with 2k oil and it literally sticks in the teeth of the gears and wont just pour out. I worry about using motor spray on plastic parts.
Any suggestions?
Qwiglee is offline
Old 07-05-2012, 11:47 AM
  #3070
Any suggestions?
some good air compressor at the track should do a good work.
jorgesimes is offline
Old 07-05-2012, 11:49 AM
  #3071
Fred Hubbard's Avatar
Any suggestions?
The easiest way to clean it is to remove all of the outdrive components and then you will be able to spray it out with motor spray without harming the oring.
Fred Hubbard is offline
Old 07-05-2012, 11:51 AM
  #3072
Essnowyt's Avatar
Any suggestions?
You can use motorspray with the Xray plastic. I have seen some off-roaders, mainly with really think 1/8 scale fluids, dump in 100wt shock oil first. This loosens the fluid and make it flow better. Then motorspay the parts clean. Personally I just use blue towels to absorb the fluid and again motorspray clean.
Just remember do not spray the rubber/silicon seals.
Snowy.
Essnowyt is offline
Old 07-05-2012, 11:55 AM
  #3073
Regional Moderator
CarbonJoe's Avatar
Any suggestions?
VM&P Naptha from Home Depot (in the paint department)... not sure on the o-ring, but I used it all the time to clean out my XRay 1/8 buggy diffs without issue. Just dump them in a glass jar and swish it around.
I assume that the o-rings in both diffs are made of the same rubber compound?
CarbonJoe is offline
Old 07-05-2012, 01:22 PM
  #3074
bvoltz's Avatar
Any suggestions?
Cleaning putty works great...
bvoltz is offline
Old 07-05-2012, 02:00 PM
  #3075
Qwiglee's Avatar
OK so I will totally disassemble and take the o-rings out and then spray with motor spray. I'm glad I checked because I was going to just open up the two halves of the diff and spray it out. Thanks for the tips.
I noticed that the big o-ring between the two halves can't be reused because it swells up and won't fit back in its slot so I ordered replacements. I'm guessing this is normal?
Qwiglee is offline
