Xray T3 2012
#2896
Hey Exotek, here's an opportunity to create some blocks that replace the existing pieces (on an XRay chassis) but are narrower. This sort of upgrade is right up your alley. Make it so!
#2899
Exotek already did this their suspension is narrower
#2902
I run on a low - medium asphalt track, thus i switch springs depending on the grip. With Tamiya springs combo of yellow at the front, and red at the rear, the car is really planted. For a HPI combo of Pink front and blue rear, it feels better driving the car but not as planted with the tamiya springs.
haven't gotten to knowing the difference in my lap times when using different springs.
hope this helps.
#2903
I use the bottom from xray amd the tamiya top with the tamiya fluorine coated 5mm ball nuts. That way i can change the possition of the shock forward or backwards more. The standard ball ends in the kit also work but u will need a 3mm locknut to secure it and there is no room voor any shims that way.
I also use the standard xray spring retainer. For setup i pretty much always will use hpi silver front and rear and maybe gold/silver or pink silver on high bite or carpet.
In my opinion the xray shocks are good enough when u got the time and patience to refill them all the time. But the tamiya's are more consistant in either filling and on the track.
#2904
#2905
Top and bottoms mean the install hardware so the part that snaps onto the top ball and the bottom ball.......i have trfs on my t3 2012 and all i did was ream out the top cap to accept the xray tops and used the xray bottoms and they fit perfectly
#2906
Xray then free-issued the solid part so people had the choice.
I won't run the split blocks indoors as I do too much damage as it is, but I always run the split blacks on asphalt as it helps gaina little extra steering.
Skiddins
#2907
It's a worthwhile upgrade for sure, hope it helps
#2909
I too have the Tamiya shocks coming with the Exotek bits,
What is needed to be done to mount them exactly where the original ones go, and to make them fit,
I have been told I need to ream the top alloy thing to allow the X-ray joint thingy to fit in to the alloy parts, as well as machine the shafts down a bit or something.
However, couldn't I just use my original Xray shock shafts rather than bring the new ones down or am I way off all together on this lol
Nathan
Nathan
#2910
Nathan
Nathan
